Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: binfordm715 : The Transformation continues....
  1. #21
    Default socal715 :
    Re: The Transformation continues....
    Post by socal715 on May 15, 2006, 1:47pm
    Yeah, but im wondering if i switched to that setup.. will i have to rotate them every 1000 miles? or what.
  2. #22
    Default elwenil :
    Post by elwenil on May 15, 2006, 1:55pm
    I dunno. anyone have any contacts at a USMC Motorpool?
  3. #23
    Default socal715 :
    Post by socal715 on May 15, 2006, 1:57pm
    my buddy said every oil change..?
  4. #24
    Default elwenil :
    Post by elwenil on May 15, 2006, 2:02pm
    Typically I change my oil at 3000 miles and rotate at 6000. I wish Lee and Tom were still here since they ran the XLs for a long time and might have an opinion on this. I'll post it over at SS and see what they say since a lot of them run the larger XLs on single rims on the M35s.
  5. #25
    Default socal715 :
    Post by socal715 on May 15, 2006, 2:06pm
    That would be appreciated.. thanks.
  6. #26
    Default elwenil :
    Post by elwenil on May 15, 2006, 3:03pm
    Hmmm, interestingly I may have just proved myself wrong. Here is a PDF file from logsa.gov that has info on the HEMMT tires and states that any XL tire should all be mounted with the tires running in the same direction.
    https://www.logsa.army.mil/pub/psiss.../613-18-19.pdf
    This means to truly rotate the tires you will have to dismount them. To me, this is unacceptable, so unless I can find some horrible reason why I cannot run them backwards, I will.
  7. #27
    Default drvnkaiserdaily :
    Post by drvnkaiserdaily on May 15, 2006, 3:11pm
    Good luck! Ju st finished engine swap and overdrive on mine.Fresh colors next. Thank goodness no rust! Drvnkaiser
  8. #28
    Post by drvnkaiserdaily on May 15, 2006, 3:15pm
    Mine is being used daily to deliver backhoe and bobcat.! bought 2 of these things last year and got totally hooked.I also got 4th place at local truck pulls last weekend.
  9. #29
    Default elwenil :
    Post by elwenil on May 15, 2006, 3:20pm
    Actually after re-reading this it seems more than a little confusing. The three tires the PDF talks about are the Goodyear AT2A, the Michelin XL and XZL. The pertinent quotation is:
    Quote:
    All three tires have non-directional tread, so it does not matter how they are mounted on the wheels. The tread can point forward or backward, although the tread on any XL tires used should point in the same direction.
    So what does this mean? It does not matter how I mount them as long as they are all mounted the same way? That is ridiculous.
  10. #30
    Default bigwheelbob :
    Post by bigwheelbob on May 15, 2006, 3:35pm
    I cant see the truck driving to good like that.
  1. binfordm715 : Stencils
    Last Post: November 12th, 2009, 03:01 AM
  2. binfordm715 : Okay... Who do I own?!
    Last Post: November 11th, 2009, 05:43 AM
  3. binfordm715 : The transformation has begun...
    Last Post: November 11th, 2009, 12:41 AM
  4. M715 Transformation project
    By Duane in forum Open Discussion
    Last Post: September 25th, 2009, 10:29 AM
  5. My build continues
    By heepey in forum Modified Tech
    Last Post: September 26th, 2007, 11:56 PM
