Results 1 to 9 of 9
Thread: vrod02 : Some annoying ?'s
    St. Louis, Mo.
    Default vrod02 : Some annoying ?'s
    Some annoying ?'s
    Post by vrod02 on Oct 11, 2006, 7:41am
    How well does the M715 turn? radius? Left or Right tighter like the M38 or willys? Got good heaters and defrost?Looks like the brakes are the biggest consern from what I've seen! What Master cylinder is the best for conversion. I'll stop there.
    For now. Vrod
    Default rollie715 :
    Heaters
    Post by rollie715 on Oct 11, 2006, 7:54am
    Most M715's came from the factory with no heater or defrosters installed. The easiest is to pull a heater out of a civilian Fullsize Jeep and put it in. It will mostly bolt right up and works great.
    Rollie
    Default brute4c :
    Re: Some annoying ?'s
    Post by brute4c on Oct 11, 2006, 9:56am
    Turning radius is 56' in the manual...I have taken mine out on the frozen lake with several inches of undisturbed snow...stopped...cut the steering hard to one side...low gear idled a complete circle and measured it at 56 feet...so that should be the diameter not the radius right?
    I have never measured left versus right...dont notice the difference in the seat...
    If you go with a converter from 24 to 12 volts rated like 20 amps or better OR a 12 volt conversion, the civvy heaters work.
    You can get the full heater setup in 24 volt, NOS, from VPW...runs around $400 for everything...includes all wires, ducts, heater core, cables, fan and switch, defroster dusts, etc....pricey but nice for 24 volt setups. I had a civvy heater I ran with a converter, I now have the NOS 24 volt one. The 24 volt one has a 2 speed fan and high on that is much higher than the high on the 3 speed civvy fan I had before.
    St. Louis, Mo.
    Default vrod02 :
    Post by vrod02 on Oct 12, 2006, 8:37am
    O.K. So does the truck have a "stock" location for the heater core? Cant believe they would'nt come with one.
    Washington State
    Default fisherman :
    Post by fisherman on Oct 12, 2006, 9:18am
    Same as stock location on a FSJ, under dash passenger side, passenger side engine compartment thru firewall. I haven't installed mine yet, had it mocked up once. Fisherman
    Default brute4c :
    Post by brute4c on Oct 12, 2006, 10:09am
    All the mounting holes and locations are there AS LONG AS someone hasnt done any mods to the firewall....
    St. Louis, Mo.
    Default vrod02 :
    Post by vrod02 on Oct 12, 2006, 10:13am
    Do they have vents in the dash for defrost? Where were original on/off fan controls located?
    Mar 2004
    northern Arizona
    Default compexp :
    Post by compexp on Oct 12, 2006, 10:57am
    cable controlled knobs on left side of steering wheel iirc. There are defrost holes in the dash - if you're missing the plastic vent pieces, ABLinn, VPW, or Memphis might have them.
    Default brute4c :
    Post by brute4c on Oct 12, 2006, 12:13pm
    If you look on the bottom edge of the drivers side of the dash panel, you will see the 3 holes where the 3 cables come through to run the doors for heat, defrost and fresh air selection....just above the location of these, on the flat part of the panel is where the directions say to mount the fan switch.
  1. vrod02 : Weird
    By vrod02 in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 06:20 AM
  2. vrod02 : Hand Throttle?
    Last Post: November 12th, 2009, 05:28 AM
  3. vrod02 : Best tire?
    Last Post: November 12th, 2009, 04:53 AM
  4. vrod02 : Who's got Troop seats in the bed?
    Last Post: November 12th, 2009, 04:41 AM
  5. vrod02 : The Hubs.
    Last Post: November 12th, 2009, 04:35 AM
