Results 1 to 5 of 5
Thread: dxeflyr : Tailgate hardware?
    Default dxeflyr : Tailgate hardware?
    Tailgate hardware?
    Post by dxeflyr on Oct 25, 2006, 1:00am
    Finally got a tailgate this week. The problem is, the metal tabs normally welded to the back of the bed to secure the gate are missing on my truck. Are they available? Has anyone else had this problem?
    Default kwai :
    Re: Tailgate hardware?
    Post by kwai on Oct 25, 2006, 10:17am
    The tabs used to latch the tailgate are welded on. Look to be about 3/8 steel.
    Port Orchard, Wash.
    Default binfordm715 :
    Post by binfordm715 on Oct 25, 2006, 11:32pm
    Here ya go, Bill. I think this is what you're after:
    That's on the passenger side. Driver's side is a mirror image, as you probably guessed!
    Default barrman :
    Post by barrman on Oct 26, 2006, 8:26am
    Here are the measurements to go along with the pictures.
    1-3/4" side to side x 2-1/2"
    The tab below his quarter is 1-1/4" from the bed to the end of it. The chain hole is 1/2" diameter in the middle of it.
    The angle on the top of the hook side starts 2-3/8" from the bottom. (I measured from where the bottom would be if the little 3/8" on each side notch hadn't been there.)
    The slot for the hook is just a hair over 1". Just make it exactly the same as the slot in your tailgate. Matter of fact, you should make it from the tailgate slot so it lines up right anyway.
    Default dxeflyr :
    Post by dxeflyr on Oct 26, 2006, 5:51pm
    Thanks a lot for your efforts, Tim! I really appreciate it. I will go down to the hangar and get a couple of these cranked out next week. Thanks again!
  1. dxeflyr : Bed tie downs
    Last Post: November 11th, 2009, 12:23 AM
  2. dxeflyr : Need electrical help, again...
    Last Post: November 11th, 2009, 12:10 AM
  3. Tailgate hardware
    Last Post: December 24th, 2006, 04:48 PM
