I have just done an engine swap in my '67 715. I put in a J truck running gear consisting of a '79 360/T-15/Dana 20. My dad usually does all the electrical and I do the mechanical stuff. I told him that the 715 came from the factory set up for 24 volts so he is swapping everything over right now. We have swapped out most all bulbs, but we are trying to get the original gauges to work if possible. The only one we have been able to move the needle on by just putting power to it is the temperature guage. My question is will the original gauges be able to work and if so how will I need to get my dad to wire them up? Thanks for any help, I did a search and couldn't find exactly the answer I was looking for, Chris.
