Old June 3rd, 2017, 09:21 PM
tomb's Avatar
tomb tomb is offline
tomb is a Soldier
Default yes its a total rebuild
its a 1968 with a chevy 350 thrown rod, chevy sm420 trans. and a bad fuel tank.
inside fuel tank
bottom after trying to fix
after welding shop put a new bottom on it
Old June 4th, 2017, 08:31 AM
Nailhead Nailhead is offline
Corporal
Nailhead is a Soldier
Bad fuel tank means you're in good company around here. Nice fix.
Old June 4th, 2017, 11:40 AM
tomb's Avatar
tomb is a Soldier
with the new bottom add it was time treat the rust in side. I used 1 part molasses 10 parts and let sit for 7 days. got side tracked so it sat about two weeks.
Old June 4th, 2017, 11:05 PM
tomb's Avatar
tomb is a Soldier
after a lot of washing and drying I sealed the bottom with PRO 15 fuel tank sealer.
Old June 5th, 2017, 03:23 AM
ray steadward ray steadward is offline
Private 1st Class
ray steadward is a Soldier
Molasses and what? First time I've heard this trick....
Is that real money?
  #6
Old June 5th, 2017, 06:44 PM
jeeper's Avatar
jeeper jeeper is offline
Sergeant
jeeper is a Soldier
Quote:
water
  #7
Old June 5th, 2017, 10:53 PM
tomb's Avatar
tomb is a Soldier
fixed the sender hole and used a 14" tube sender with gage.
finished it off with PRO 15
  #8
Old June 6th, 2017, 07:19 AM
Von's Avatar
Von Von is offline
Corporal
Von is a Soldier
Molasses and water... Never heard of that. Looks like it did a good job though! Tank looks great.
I guess molasses isn't a total waste of sugar. Maybe it's an acquired taste or something you have to grow up with to like. I made a shoofly pie a few years ago... disgusting. I'll stick with chocolate, buttermilk or sweet potato pies.
  #9
Old June 6th, 2017, 03:25 PM
Jonnie's Avatar
Jonnie Jonnie is offline
Jonnie is a Soldier
You have to let it sit and ferment, which produces acid. Just add water as it evaporates. Covering your container helps. Not for in the house, it stinks.
Jonnie
  #10
Old June 6th, 2017, 04:54 PM
Von's Avatar
Von Von is offline
Corporal
Von is a Soldier
Quote:
Wonder if that would have helped the pie.
1998 - 2019
Copyright 1998-2019
