  #141
Old September 11th, 2018, 07:24 AM
Von's Avatar
Von Von is offline
Corporal
Von is a Soldier
I'm diggin the carb linkage.
I had an ongoing problem with the fancy braided steel cable I was using. Having to loop it around to get over to the carb and it would drag inside the braided steel sheath. Hung up pretty good right off idle... made taking off an adventure.
Wasn't too bad with the 350 in it but after the 390 swap it was awful...
Ended up going with a bare cable and pulley system till I get around to something better. But this actually works really, really well.
IMG_20180806_143211780_LL by kerry walker, on Flickr
  #142
Old September 11th, 2018, 10:34 AM
tomb's Avatar
tomb tomb is offline
tomb is a Soldier
that linkage was the one that was on the truck but didn't fit right when going back together
  #143
Old September 22nd, 2018, 06:14 PM
tomb's Avatar
tomb is a Soldier
bumper
m715 310 by tom boyer, on Flickr
m715 311 by tom boyer, on Flickr
m715 309 by tom boyer, on Flickr
m715 312 by tom boyer, on Flickr
  #144
Old September 29th, 2018, 10:27 PM
tomb's Avatar
tomb is a Soldier
cut 2" out of side of the bumper going from 8" to 6"
m715 313 by tom boyer, on Flickr
bumper done
m715 314 by tom boyer, on Flickr
  #145
Old September 30th, 2018, 05:49 AM
Von's Avatar
Von Von is offline
Corporal
Von is a Soldier
That's a bumper! Work bumper slash picnic table, I like it.
  #146
Old September 30th, 2018, 09:02 AM
tomb's Avatar
tomb is a Soldier
did you check out the bear plate number
  #147
Old September 30th, 2018, 10:54 AM
Von's Avatar
Von Von is offline
Corporal
Von is a Soldier
Quote:
NO, I didn't even notice it! Too busy checking out the bumper it's bolted to.
That's cool!
I thought about going HUGE on my bumper if I could come up with a design that wasn't too obnoxious. My truck spends way more time in hardware store parking lots than in fields or working so I went with a more knee bone friendly version. It's still a parking lot menace though. And as it is I have about 3 inches clearance on each end when I park it in my shop. I can't even use a roller fairlead...
  #148
Old December 23rd, 2018, 10:34 PM
tomb's Avatar
tomb is a Soldier
tail gate chain all stainless steel
m715 315 by tom boyer, on Flickr
had a push rod spraying a steady stream of oil when I went to adjust the valves had a bad lifter with a bent flapper plate
m715 318 by tom boyer, on Flickr
m715 317 by tom boyer, on Flickr
  #149
Old May 28th, 2019, 06:00 PM
tomb's Avatar
tomb is a Soldier
grill build lay out
https://flic.kr/p/2g3g9Fh
milling out slots
https://flic.kr/p/2g3fZZf
  #150
Old May 30th, 2019, 12:54 PM
tomb's Avatar
tomb is a Soldier
grill done
https://flic.kr/p/2g3g96p
https://flic.kr/p/2g3fZno
https://flic.kr/p/2g3g4FQ
