Go Back   M715 Zone > General Tech > Stock Tech > Stock Tech Archives
Stock Tech Archives Look here first for all archived messages
Old March 20th, 2004, 07:53 PM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
Default Rear locking hubs?
I am repainting my windshield frame this weekend. My rubber gasket between the cowl and frame is in good shape. The problem is that it is the white color the truck was painted. Does anyone have any suggestions on how to remove the paint without distroying the rubber? I was thinking of gasoline.
Old March 20th, 2004, 08:16 PM
Doug's Avatar
Doug Doug is offline
Das Fire Führer!
Doug is a Soldier
Default Windshield Drain
I just used paint stripper, didn't notice any adverse effect on the gasket.
Old March 20th, 2004, 08:25 PM
Barrman's Avatar
Chief 9-flats
Thanks. I plan on replacing it when I tear down and paint the entire truck. I just need it to last another year or so. The rebuild will happen one I get all of my mechanical modifications done, road tested, modified better, re-road tested, fixed again, beat with a BFH and accept that that is as good as it will get.
Old March 20th, 2004, 08:49 PM
tacoma tacoma is offline
Corporal
tacoma is a Soldier
gas is not good for rubber. There are paint strippers available that will not hurt it.
**I heart Bump_r **
Old March 21st, 2004, 05:40 PM
Joe/Ia Joe/Ia is offline
New Recruit
Joe/Ia is a Soldier
Default Pilot Bearing removal....
In the past I have cleaned paint off of rubber pieces such as weatherstripping, etc. with a sandblaster. You would think it would destroy the rubber, but it doesn't. Apparently because the rubber is resilient the sand doesn't tear it up. Try it carefully, I think it will work for you.
Joe
  #6
Old March 28th, 2004, 07:07 PM
Nuke_cobe308 Nuke_cobe308 is offline
New Recruit
Nuke_cobe308 is an Observer
I have taken paint off rubber with tire cleaner. It takes a little elbow grease, but works well.
  #7
Old March 31st, 2004, 09:11 PM
fisherman's Avatar
Sergeant
fisherman is a Soldier
Lacquer thinner works wonders, wear gloves, wet a rag and slowly wipe the paint, it will soften and come off, the lacquer thinner will remove a little rubber making it look brand new, it seems to soften the harder rubber to giving it a new look. It worked great on my windshield rubber. Good Luck Fisherman
HTML code is On
airborne : Windshield glass gasket, airborne PseudoZone - Open Archive 12 November 12th, 2009 03:13 AM
Oil Pan Gasket AWB Stock Tech 4 May 17th, 2009 05:38 PM
Gasket, yes or no? fng Stock Tech 7 March 2nd, 2009 05:53 PM
Windshield glass gasket Archiver Open Discussion Archives 0 December 24th, 2006 02:44 PM
