Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: jeepcj : Chevy 427 tall block vs Caddy 472
    Default tacomainoh :
    Re: Chevy 427 tall block vs Caddy 472
    Post by tacomainoh on Aug 15, 2006, 1:02am
    Which will be easily made by swapping output shafts... and tailhousings.
    Default bigwheelbob :
    Post by bigwheelbob on Aug 15, 2006, 6:45am
    I guess that depends if you know how to gut a transmission and put it back together, but youre correct, not to hard.
    Default jeepcj :
    Post by jeepcj on Aug 15, 2006, 7:56am
    Why will the shaft lenght matter? A NP 205 is going in also. So can I just mount it back further? The drive shafts will be new so they will be made the correct length.
    Default raven :
    Post by raven on Aug 15, 2006, 3:31pm
    Did the 400 come out of a car, or is a 4wd version? If it's a 2wd version out of a car, you've got to do as stated previously to mate up a t-case to it. Also, you've got to use the correct output shaft to properly fit the t-case you're planning on using.
  5. #15
    Default jeepcj :
    Post by jeepcj on Aug 15, 2006, 8:27pm
    The 205 is a divorced case so it just slide back. Yes?
  6. #16
    Default raven :
    Post by raven on Aug 15, 2006, 8:52pm
    Ahhh, that's different. Yeah, I suppose that would work out just fine. Would put the t-case just about center of the rig, and you 'd have driveshafts of just about equal length.
    Might put the t-case far enough back to interfere with the fuel tank?
  7. #17
    Post by tacomainoh on Aug 15, 2006, 10:51pm
    well, you could move the Tcase crossmember back a ways.
    The Caddy trans came with the longest 2wd output shaft if I'm remembering right. Like, 8" longer than the short ones.
    RAVEN: ever see a 4wd Cadillac with a TH400??? LOL
  8. #18
    Default jeepistdougiowa :
    Post by jeepistdougiowa on Aug 15, 2006, 11:18pm
    And have the correct tools. I'd not recommend the job to someone who's never messed with auto transmissions. I've done a handful and not much annoys me more.
  9. #19
    Default raven :
    Post by raven on Aug 16, 2006, 2:26am
    Actually, yeah I have, as rediculous as that is. lol
    Have you never seen a big block caddy in a 4wd backed by a BOP TH400 case and a 205? Not a real common set up, but they're out there. In fact there was a REAL good look at a freind of mine's in Peterson's a couple of months ago (except it is backed by a 203/205).
    He didn't specify what the 472/TH400 came out of. I assumed it was 4x4 since he was considering putting it into the Kaiser. Using a 2wd case and divorced 205 never occurred to me. What was that old saying about when you "ass-u-me" something? LOL
  10. #20
    Post by tacomainoh on Aug 16, 2006, 2:32am
    Well that's not really a Caddy LOL and the Escalade DOESN"T COUNT!!!! heheh
    I'll be running a Buick 455, w/the same mod. The TH400 is remarkably adaptable to so many things. I have one with a 203/205, one with the 205, another with a 241. All 32spl.
  1. 6.2 where a big block chevy was? sm 465
    By res0wc18 in forum Modified Tech
    Last Post: May 7th, 2009, 08:53 PM
  2. 427 Chevy Tall Deck Question
    By pacebm in forum Modified Tech
    Last Post: September 4th, 2008, 11:14 AM
  3. Small Block or Big Block Chevy Swap
    By jrok93003 in forum Modified Tech
    Last Post: April 28th, 2008, 03:47 PM
  4. another small block chevy question
    By da mule in forum Modified Tech
    Last Post: September 24th, 2007, 09:40 AM
  5. Big Block Chevy
    Last Post: July 30th, 2006, 04:18 PM
