Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: What guage sheet steel for home fab fuel tank?
  1. #11
    Have you seen the stock baffle. It is like the side of the stock tank with a four corners notched off. It is mouunted slightly off center towards the passenger side of the truck and runs lenghtwise the same direction as the truck. SIMPLE
  2. #12
    good boy! remembering the return line. For what it's worth, my carb'ed FSJ has either many vent lines or a return line as it is. I've been thinking about baffles lately myself... mostly on how to make one that will keep gas coming to the pump going uphill, without starving it going down. It's a challenging problem.
    **I heart Bump_r **
  3. #13
    San Antonio,Texas
    tacoma- no it won't warp if you weld in the baffles first and tack it good all around.
    spicer- make the baffle the same size as the inside of the tank and cut a couple of half-moons at the bottom. about half on a 2" diameter hole. the idea is to slow down the liquid so it doesn't slosh. you should be able to use the stock gas cap too.
    doug - yes simple is best.
    67 M725 84 GW
  1. Fuel tank
    By randygar in forum Open Discussion
    Last Post: April 28th, 2014, 09:14 AM
  2. Fuel guage and sender install
    By randyscycle in forum Modified Tech
    Last Post: March 29th, 2013, 11:40 AM
  3. 12 v fuel sender and guage
    Last Post: August 8th, 2008, 12:42 PM
  4. Stainless Steel Gas Tank I made...
    By ChalkOutline in forum Modified Tech
    Last Post: March 3rd, 2008, 06:41 PM
  5. Adjusting an Autometer Fuel Guage
    By fng in forum Modified Tech
    Last Post: September 9th, 2007, 08:02 AM
