Need some help, maybe its a no-brainer, but I need to step back and rethink.
Stock engine.
Rebuilt carb to spec. Fuel pump puts plenty of gas into carb, fuel filters new. Choke level set correctly. FRESH gas, all old gas removed.
Here's the dilemma. Starts instantly with full choke, I'll then quickly drop to 1/2 choke. Runs good, no missing, steady rpms. After a few minutes of warm up, when I try to drop off the choke, the engine intantly dies. Will restart right away, but always does the same thing with the choke. Will rev up, no missing at higher rpms, seems good there.
I didn't check for air leaks around base, but new gasket installed. Will try spraying around base tomorrow. Didn't seem where I set the idle mixture needle made much of a difference.
I did not have the air cleaner on, nor the vacuum lines hooked up to it. Truck does not have governor, early model.
Any ideas?
Scott
