Results 1 to 9 of 9
Thread: luckypabst : Parking brake question
    Lone Pine, CA
    Default luckypabst : Parking brake question
    Post by luckypabst on Jul 11, 2006, 3:40pm
    Mainly directed at Cowan here with his brake relining but chime in if you can:
    Will a properly adjusted non-oily brake band stall the truck? I'm having issues with Frapguy's oil soaked brake band over here. To get it to work nice, it needs to be adjusted tight enough that it builds some heat when driving.
    Anyone have a link to the proper adjustment method?
    I've never had the brake on mine working right, never really cared, so I'm not sure how powerful the parking brake should be.
    Chris
    Default brute4c :
    Re: Parking brake question
    Post by brute4c on Jul 11, 2006, 3:55pm
    Mine would drive but would soon stop the truck due to the heat swelling it...the 1 or 2 times I drove off without releasing the brake that is...
    Heres the manual link:
    http://www.m715zone.com/manuals/34/chapter16.html
    That page has both the service brakes and the parking brake....its in there...
    Lone Pine, CA
    Post by luckypabst on Jul 11, 2006, 4:02pm
    Thanks Jon, I'll give it a go in a little bit.
    Chris
    Default robertcowan :
    Post by robertcowan on Jul 11, 2006, 4:19pm
    if you drive with the brake engauged it will cristalize the linning, and----- cook the seal out of the output shaft if run long enough. it get super hot quick. been there done that.
    Lone Pine, CA
    Post by luckypabst on Jul 11, 2006, 4:25pm
    Yea I figured that much, but I wanna know if the brake is strong enough to stall the engine from a standstill.
    Chris
    Post by robertcowan on Jul 11, 2006, 5:37pm
    YESit will if ait adjusted correctly and the drum is good and true.
    Default barrman :
    Post by barrman on Jul 11, 2006, 8:39pm
    I agree with Bob Chris. A properly adjusted brake should definitely stall the truck in second even with throttle applied. You might be able to make it move in granny with lots of throttle, but then it is a race to whether the clutch or brake goes first. I am referring to the 230.
    Lone Pine, CA
    Post by luckypabst on Jul 11, 2006, 10:05pm
    Cool thanks guys.
    Engine is a baseline GM crate 350 - not much if any torque over the 230. I told him about the relined brake bands but I'm not sure he's willing to put any money into his E-brake.
    Chris
    Post by robertcowan on Jul 11, 2006, 11:35pm
    if he,s got the stock master cyl. i highly recomend haveing a e-brake. better safe than sorry.
  1. disc parking brake
    By osut362 in forum Modified Tech
    Last Post: May 11th, 2011, 01:30 PM
  2. alex : Parking brake
    Last Post: November 12th, 2009, 06:46 AM
  3. NP205 Parking Brake
    Last Post: January 16th, 2009, 02:32 PM
  4. Parking Brake Specs
    By Jester in forum Stock Tech
    Last Post: September 9th, 2008, 12:06 PM
  5. Hydro parking brake
    Last Post: January 2nd, 2004, 02:46 PM
