Results 1 to 10 of 14
Thread: bluesman2a : Did I mention I HATE sheetmetal work?
    Atlanta, Ga.
    Default bluesman2a : Did I mention I HATE sheetmetal work?
    Post by bluesman2a on May 13, 2006, 2:07pm
    Little progress report, been working on repairing the large holes I had to cut to "repair" the damage from the P.O. (looks like he just beat the crap outta the firewall to "clearance" and then gnawed through the sheet with a dull gerbil where he needed a hole.
    Before:
    After:
    New plate to mount forward battery-box.
    I'll tell you, while I don't much care for this work, for anybody who has to do it, .023 wire makes ALL the difference in the WORLD. I was actually able to lay a pretty decent bead and not have to "spot" everything. No warping, not a lot of heat transfer into the work piece.
    I probably could have made it look a little better with some filler, but it's solid and water tight for now, that's all I care about...
    Default k8icu :
    Re: Did I mention I HATE sheetmetal work?
    Post by k8icu on May 13, 2006, 9:00pm
    Better than I would have done. I would have been the dull hamster looking than your "professional" job. Looks very good!
    Huntingtown,Md.
    Default airborne :
    Post by airborne on May 14, 2006, 9:01am
    Looks GREAT! If JB weld can't do it I'm S.O.L!
    Oxford, Ohio 45056
    Default elohim1 :
    Post by elohim1 on May 14, 2006, 12:50pm
    Looks great guy.
    I cant help but notice the steering column and shaft that connects to your psc unit.
    Where did you get these items?
    My PSC unit is on the way, was thinking of going with a tilt column why I am at it.
    Chris
    Atlanta, Ga.
    Post by bluesman2a on May 14, 2006, 1:09pm
    Quote:
    I cant help but notice the steering column and shaft that connects to your psc unit. Where did you get these items?
    Thanks for the kind words, Chris. It's all actually aftermarket. You can get a couple more pics of the install here:
    http://www.sjmembers.com/gallery/vie...umName=album40
    Part numbers are as follows:
    IDT-1120300010 STEERING COLUMN
    http://store.summitracing.com/egnsearch.....ts=false&N=115
    IDT-2401300010 2 ADJUSTABLE FLOOR MOUNT
    http://store.summitracing.com/egnsearch.....earch&DDS=1&N=0
    IDT-2401500040 2 SWIVEL BALL FLOOR MOUNT
    I also had a borgeson steering shaft (for a CJ) that worked well after I cut it down a little. A donor from a waggie or CJ would also work with the proper ends, but both are notorious for slop.
    If you are buying a NEW steering shaft, and you are using the aftermarket column, you will need the standard CJ connector on the box side (not sure of spline count and on the other side you will need a 1" DD to 1" DD steering u-joint to connect to the column.
    http://store.summitracing.com/partdetail....15&autoview=sku
    If you have questions, feel free to either pm or email me. This stuff isn't hard, but it's tedious and a couple of little gotchas, be happy to share what I've learned.
    If there's interest, I'd be happy to do a steering post for a sticky on the new board when it comes back.
    Port Orchard, Wash.
    Default binfordm715 :
    Post by binfordm715 on May 14, 2006, 11:19pm
    There's interest!
    Default brute4c :
    Post by brute4c on May 15, 2006, 8:43am
    Please do that sticky!!!
    Oxford, Ohio 45056
    Default elohim1 :
    Post by elohim1 on May 15, 2006, 8:30pm
    Quote:
    There's interest!
    Ditto !!!!!
    Oxford, Ohio 45056
    Default elohim1 :
    Post by elohim1 on May 16, 2006, 7:39pm
    Is this the best borgeson shaft for the job ?
    or this one which has a shorter extension range but is for manual steering.
    Atlanta, Ga.
    Post by bluesman2a on May 16, 2006, 11:11pm
    Chris,
    The problem you are going to see is that if you order the stock one you'll need to put a different end on one side like I did. Not sure which is more economical, but you could also build your own using the separate components as below:
    This shaft (universal)
    http://store.summitracing.com/egnsea...115+4294849064
    This Joint for the steering column side, assuming you are using the aftermarket like I did (1" DD to 1"DD)
    http://store.summitracing.com/partdetail....5 &autoview=sku
    On the box side you will need a 3/4" DD to a splined 13/16-36 input for the PSC steering box.
  1. bluesman2a : New Lines...
    By bluesman2a in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 03:03 AM
  2. Another reason to hate wiring
    By Tomahawk715 in forum Modified Tech
    Last Post: May 24th, 2008, 12:48 AM
  3. Sheetmetal?
    By Nuke_GreenMachine in forum Stock Tech Archives
    Last Post: May 25th, 2004, 07:41 PM
