Results 1 to 7 of 7
Thread: What carb is stock ? ?
    Default What carb is stock ? ?
    After I did a Chev 350 conversion, I sold the engine with the carb.
    Which carb is stock on the Tornado engine ? I am about ready to make another carb kit order, and I might as well be stocking kits for the Kaiser.
    Thanks, Tom
    The Holley 1 barrel Model 1920 was stock...it has a different accelerator pump than most civilian motors though...
    I will double check on the accellerator pump before I order, most military carb applications are always a wee bit differant than the civi app's. Thanks, Tom
    I am a bit vague from what I meant...the accelerator pump arm is very differet on the mil version...its an external way to id the right carb...If I remember right I saw an old Ford that had the same one...in a pickup, early 60's...the Dodge ones are not correct.
    I just ordered a carb kit from Memphis Equipment. They have plenty in stock.
    This a very complete kit.
    ~$28 plus shipping.
    Would the mil version be compatible with a civy 1920?
    Its a little different...baffle in the bowl and float setting are different...the accelerator pump arm...
    Never tried to put the civvy types side by side and seee if it would bolt up and go...
  1. Stock carb kit info
    By SHOOTER68 in forum Stock Tech
    Last Post: June 3rd, 2018, 01:35 PM
  2. Alternative for stock carb and air cleaner
    By Snookie in forum Stock Tech
    Last Post: December 30th, 2010, 03:45 PM
  3. Stock carb main jet size
    By Jester in forum Stock Tech
    Last Post: October 22nd, 2008, 02:58 PM
  4. Civvie Carb w/ stock air cleaner
    By Joel in forum Modified Tech Archives
    Last Post: May 24th, 2004, 11:01 AM
