Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: binfordm715 : Discovering your truck's original color
  1. #11
    Default kwai :
    Re: Discovering your truck's original color
    Post by kwai on Nov 16, 2006, 10:59am
    My '69 has the 4-color scheme. The PO got it from the forest service and started to repaint it but didn't finish. Don't know who would have painted it camo but my quess would be it came out of the military that way since the forest service/fire guys seem big on yellow, red and white.
  2. #12
    Default shepsjeep :
    Post by shepsjeep on Nov 17, 2006, 1:40am
    Fisherman is right, not that difficult, but very messy. I used a product called " Jet Strip" I got it at O'Reilly's for about $21. I still have about 1/3 can left after stripping most of the paint off the entire truck. I stripped a little at a time over a few weeks. If you have access to a pressure washer and a nozzle called a "turbo"( it is used for removing loose paint from a house before painting), it will remove the stripper and paint goo from a distance. Water will neutralize the stripper and dries very quickly, just sand and then prime and paint. Caution: The smell will knock you out and burns really bad if it should touch your skin. Wear eye protection, clothes you don't want and a mask!
  3. #13
    Default barrman :
    Post by barrman on Nov 17, 2006, 4:08pm
    Mine was USMC green behind the data plate as well.
  1. What were YOUR original hood numbers?
    Last Post: May 10th, 2009, 11:04 PM
  2. upgrading original parts
    By Rakes67 in forum Modified Tech
    Last Post: February 11th, 2009, 08:13 PM
  3. has my bed been cut or is this the original?
    By stepsidedan in forum Open Discussion
    Last Post: December 15th, 2008, 07:24 PM
  4. specs from an original 67?
    Last Post: August 17th, 2008, 10:41 AM
  5. Original color of the Tornado valve cover?
    By maddawg308 in forum Stock Tech
    Last Post: July 16th, 2007, 11:10 PM
