Results 1 to 9 of 9
Thread: M725 max weight ???
    Default M725 max weight ???
    Hello guys !
    I am in search for the maximum allowed weight (loaded) for an M725
    Any help will be greatly apreciated
    Jun 2007
    Alexandria KY
    Refer to the Data plates on the truck.
    '67 M715 '42 GPW '45 MB
    I wish I could Roy.
    Someone was paint over them
    8800 GVW + 2000 useful load = 10800 lbs Max Gross
    Numbers are from the online version of the users guide. See online Maintenance Manual link at the very top of this page
    According to the manuals:
    CURB WEIGHT, FULLY EQUIPPED, LESS PAYLOAD AND CREW
    Front Axle 2,800 lbs.
    Rear Axle 3,600 lbs.
    Total 6,400 lbs.
    PAYLOAD*
    Cross Country 2,000 lbs.
    Highway 2,000 lbs.
    GROSS WEIGHT, FULLY EQUIPPED, PLUS PAYLOAD AND CREW
    Front Axle 3,000 lbs.
    Rear Axle 5,800 lbs.
    Total 8,800 lbs.
    *Add 2 man crew and gear, 400 lbs.
    so bascally, its 6400 lbs empty and 8800 lbs loaded...which includes 400 pounds for crew and ger and 200p for payoad...or 2400 lbs. total.
    Awesome info guys thanks !
    The M725 in question was still in the Hellenic Army (decomissioned) but the Greek law says that all vehicles below 2.5tons cannot be sell to indivuals as they must be recycled (!!!!).Sounds unheard of but this is it!
    BUT any vehicle over 3.5tons can be sold privately
    Sooo I will start the paperwork really soon (I hope)
    a BIG thank you to all for your priceless help
    Forgot to mention : this law is not valid for cars who are already road registered!!!
    Aug 2009
    Madison Heights, MI, just outside Detroit
    My data plate shows 8400 pounds max weight wether on highway or off road.
    If I am not mistaken, the data plate shows 8400 lbs in both configurations and then one adds the 400 lb. allotment for the crew and gear.
    The manual does state that the payload is 2000 lbs. for both on and off road, as noted above, which is different than the M715 which has a 2500 lb. off road and 3000 lb. on road rating.
    Does your data plate have a blurb at the bottom of the section on weight about the 400 lb. allotment for crew/gear?
  1. d60 / 14 weight
    By noreallyicanfixit in forum Open Discussion
    Last Post: December 3rd, 2009, 09:13 PM
  2. foreverunstopable : Lav Weight
    Last Post: November 12th, 2009, 01:38 AM
  3. weight of the m715?
    By Agent Orange in forum Stock Tech
    Last Post: July 18th, 2009, 09:48 AM
  4. Michelin XL weight
    By Mikel in forum Open Discussion
    Last Post: November 13th, 2007, 06:06 AM
  5. Heavy weight m725
    By slowride/wy in forum Open Discussion
    Last Post: February 27th, 2007, 08:13 PM
