Results 1 to 3 of 3
Thread: Headlight switch breaker?
    Default Headlight switch breaker?
    every once in awhile I'll be driving and my lights will randomly die. I'll shut them off for a second and then turn them on again and they will work for a little while before they die again. I don't think there is any problem with the wiring shorting out so i was wandering if there is a breaker within the switch itself and if it is common for the breaker to fail... also, my truck is converted to 12 volts if that makes a difference...
    thanks
    -Brian
    there is a breaker in the switch it isnt serviceable though , it has come up alot here before about that breaker triping on 12v conversions it was related to add a relay in the wiring to the headlights. it was just a few post ago it was under light switch or 3 way switch
    68 M-715 MVPA #2710
  1. Headlight switch and turn conversion
    By CHRIS UNGER in forum Modified Tech
    Last Post: March 22nd, 2010, 08:02 AM
  2. will a 3 lever headlight switch work with 12v
    By Duane in forum Stock Tech
    Last Post: February 21st, 2010, 06:53 PM
  3. Steering column and headlight switch
    Last Post: October 28th, 2007, 10:55 PM
  4. multifunction headlight switch
    Last Post: June 13th, 2007, 09:46 PM
  5. Head light switch breaker? + master cylinder question
    By the1968jeepthing in forum Modified Tech Archives
    Last Post: February 23rd, 2004, 07:23 PM
