Results 1 to 5 of 5
Thread: gimpyrobb : Steering shaft bushing ?
    Default gimpyrobb : Steering shaft bushing ?
    Post by gimpyrobb on May 3, 2006, 8:51pm
    In moving around the Kaiser to get it ready for the F.E. I noticed that when I turn the steering wheel to the left, I get a moaning and thumping noise out of what seems to be the shaft in the column(sp?), has this happened to anyone else? I thought it might be the rag joint or something under the hood, but its not. When looking under the hood, it sounds like its behind the firewall.
    Default kaiser715 :
    Re: Anyone else?
    Post by kaiser715 on May 3, 2006, 9:10pm
    My CJ did something similar, there is/was a nylon bushing at the bottom of the shaft that was worn out. Got one of my clients, a plastic molding place, make me a new one of that slick hard plastic stuff (i forget the initials of it). Took the tool man about 10 minutes or so.
    edit: UHMW or something like that -- ultra high molecular something
    Port Orchard, Wash.
    Default binfordm715 :
    Re: Anyone else?
    Post by binfordm715 on May 4, 2006, 9:14am
    UHMW is correct. "Ultra High Molecular Weight" as I understand.
    canby Oregon
    Default 503m715 :
    Re: Anyone else?
    Post by 503m715 on May 4, 2006, 8:40pm
    Mine was doing same thing. The bushing at the end of steering shaft was trashed. I got a new one from ab Linn. If you need one and ab doesn't have any more, I think I have 1 more.
    Default devildog :
    Re: Anyone else?
    Post by devildog on May 5, 2006, 9:44pm
    Could it be UHDPE? Ultra High Density Polyethelene is used for making bearing products.
  1. gimpyrobb : Steering issues
    By gimpyrobb in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 02:25 AM
  2. Steering shaft size.
    By BulletSponge in forum Modified Tech
    Last Post: April 23rd, 2009, 12:03 PM
  3. u-joint steering shaft.
    By alosix in forum Modified Tech
    Last Post: June 22nd, 2007, 03:41 PM
  4. Steering shaft u-joint type anyone use?
    By tngreenmachine in forum Modified Tech
    Last Post: March 16th, 2007, 02:48 PM
  5. Steering shaft question?
    By spr-m715 in forum Modified Tech
    Last Post: January 2nd, 2007, 08:41 AM
