Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Let's talk more about power brakes.
    Atlanta, Ga.
    Default Let's talk more about power brakes.
    OK, I've also decided that it's time for power brakes on my junk. I'm currently running 4-weel discs on CUCV axles with a corvette master.
    I've seen a couple of other setups, I think somebody used an XJ dual diaphragm booster. I've heard this can be used in conjunction with a dodge 1-ton van MC... Which is what I'm leaning towards at the moment.
    Anybody have any other setups that work well? Recommendations? Thoughts?
    I'm using a ZJ master/booster and with the stock drum brakes it stops excellent. I'd think it would work just fine with the 4 wheel discs. The ZJ had drums on the rear, so an adjustable proportioning valve might be in order.
    I liked this setup mainly because the physical size of the booster was easier to work with.
    Jun 2007
    Alexandria KY
    Be sure to consider the residual pressure valve in the disc/drum m/c when going to 4-wheel disc.
    '67 M715 '42 GPW '45 MB
    Quote Originally Posted by Roy View Post
    Good point. Thanks!
    HYDRO BOUST.
    I was using a 90's vac booster and vet master. It stopped so so ok. I changed to a hydro boost when I put the 6.2 in. I still don't have the peddle touch yet. I will lock all 4 and put you in the windshield.
    New Haven, CT
    Quote Originally Posted by sermis View Post
    HYDRO BOUST.
    I have a "modern" set of D60/D70 in my J300, with hydroboost. Brakes are better than some cars I've had.
    Richboro,Pennsylvania
    Hydroboost rocks. My truck stops better than most vehicles I have driven.
    another vote for hydroboost. easy to make work, and with the cucv axles 4 wheel disks, my truck stops better than my 04 chevy. the brakes are probably my most favorite thing on the truck
    ryan
    67 #18820 mostly stock...
    Jul 2008
    Saginaw Michigan
    will hydro boost work with full hydro stearing?
    Default cucv hydroboost
    Quote Originally Posted by ryanroo View Post
    ryan
    What master cylinder are you using with the cucv disk brakes?
  1. foreverunstopable : Power steering/brakes of J-Series
    Last Post: December 15th, 2009, 07:56 PM
  2. Let's talk more about cages.
    By bluesman2a in forum Modified Tech
    Last Post: June 29th, 2009, 04:14 PM
  3. Hey, Lets talk BRAKES some more!!!!
    By fng in forum Modified Tech
    Last Post: March 4th, 2008, 10:59 AM
  4. Vacuum Source for Power Brakes & Other Questions
    By bdial in forum Modified Tech Archives
    Last Post: April 13th, 2004, 04:58 PM
