Results 1 to 3 of 3
Thread: warthog : Rear Rockwell axle
    Default warthog : Rear Rockwell axle
    Rear Rockwell axle
    Post by warthog on Sept 1, 2006, 8:16am
    Can the rear axle be spun 180 degrees to center the pinion (basically running the axle in reverse) or do you have to unbolt the center section, spin 180 and bolt back on? I think spinning center section requires redrillin a few bolts holes.
    Default bigwheelbob :
    Re: Rear Rockwell axle
    Post by bigwheelbob on Sept 1, 2006, 2:35pm
    You can install it in any manner you want, it will work fine.
    Default warthog :
    Post by warthog on Sept 1, 2006, 4:47pm
    Good to go, Tks
  1. 2.5 rockwell axle questions
    Last Post: March 26th, 2010, 09:11 PM
  2. rockwell steering axle boots!!!!!!!!
    By jon lee in forum Open Discussion
    Last Post: March 2nd, 2009, 03:47 PM
  3. Rockwell axle drivability
    By snakeater in forum Modified Tech
    Last Post: January 15th, 2009, 03:19 PM
  4. rear steer rockwell?
    By 503m715 in forum Modified Tech
    Last Post: January 3rd, 2008, 07:42 PM
  5. Questions about the rear-rear axle
    By Brian Sisson in forum Stock Tech Archives
    Last Post: May 21st, 2004, 08:06 AM
