Results 1 to 8 of 8
Thread: stanman : on board air
    Default stanman : on board air
    on board air
    Post by stanman on Oct 9, 2006, 8:32pm
    Hi guys. I am planning an onboard air system in the future and I have an AC compressor, but im not sure what type it is. Would it be easy to convert this one to an air compressor? I pulled it off of a 318 poly.
    any ideas?
    Default elwenil :
    Re: on board air
    Post by elwenil on Oct 10, 2006, 7:09am
    Google that around a bit and you should find a page or two dealing with using those as OBA compressors. According to some, they will run air tools no problem. I plan on running one on my 318 in my 715 at some point in the future.
    Default stanman :
    Re: on board air
    Post by stanman on Oct 10, 2006, 8:42am
    What make of pump is it?
    Default elwenil :
    Re: on board air
    Post by elwenil on Oct 10, 2006, 11:39am
    Chrysler designed and built. Think of it as two Yorks put together in a V configuration. The advantages of running this pump are the obvious twin design, and the fact that it has it's own dedicated oil system with crank driven pump.
    Default gimpyrobb :
    Re: on board air
    Post by gimpyrobb on Oct 10, 2006, 2:29pm
    Hey lanty, are you sayin that it has 4 pistons, or 2 larger pistons?
    Default barrman :
    Re: on board air
    Post by barrman on Oct 10, 2006, 3:27pm
    I used the big York for my OBA with M35 air tanks under the bed. I love it. Matter of fact, it made my 500 mile drive last weekend able to be completed. Here is the parts place that has all the "standard" OBA parts.
    http://www.kilbyenterprises.com/
    I am at home with my sick son right now. At work I have 5 or 6 more OBA sites saved to the favorites and they are mostly write ups and low dollar tech for OBA systems. Plumb it however you want, but 2 of us here on the Zone have learned from experience that at least 1 foot of metal tubing needs to be between the compressor and the flexible airlines in the system.
    Reply to this thread tonight or tomorrow and I will remember those other links.
    Default elwenil :
    Re: on board air
    Post by elwenil on Oct 11, 2006, 7:17am
    Two piston in a V configurations. When disassembled, it is very much like a small engine complete with crank, rods, heads, etc. Cool little machine that is typically overbuilt for early mopar stuff.
    Default barrman :
    Re: on board air
    Post by barrman on Oct 12, 2006, 8:44am
    Here are some links:
    http://www.jeepshots.com/tech/air.html
    http://www.visi.com/~bsimon/jeep/my_air.html
    http://www.4wdproducts.com/index.htm
    http://jeepfrog.com/78cj5/mods/air/york.html
    http://www.jedi.com/obiwan/jeep/yorkair.html
    Most of the above sites have tons of links inside them. Follow them and you will spend days looking and learning.
  1. stanman : np201
    Last Post: November 12th, 2009, 05:23 AM
  2. stanman : tires again
    Last Post: November 12th, 2009, 04:05 AM
  3. stanman : tires
    Last Post: November 12th, 2009, 03:15 AM
  4. stanman : overdrive
    Last Post: November 12th, 2009, 01:36 AM
  5. stanman : oil pressure
    Last Post: November 12th, 2009, 12:24 AM
