Results 1 to 10 of 12
Thread: NP200 heat
    New Haven, CT
    Default NP200 heat
    Hello,
    How about this to help dissippate the NP200 excess heat?
    One could easily braze (either silver braze or silicon bronze) a pocket to the NP200, put two fittings in that pocket and route the return line from the heater to that pocket. That way, the heat would be absorbed by the engine coolant and dissippated by the radiator. Brazing is very easy and there would be no need for a separate pump or cooling circuit.
    Any thoughts?
    Mikel
    Feb 2009
    Northern California
    Way too much work. My thought was to just screw fittings into the fill and drain plugs, and run them to a little oil cooler with its own fan and a little pump. Then my thought was "I'll just stick a np205 in like everyone else, when I do an engine swap."
    --Randy
    New Haven, CT
    Quote Originally Posted by randygar View Post
    How is that simpler?
    Feb 2009
    Northern California
    option a) remove the t-case, drain it, flush the insides, construct a box (probably involving welding or brazing and grinding the edge to a perfect match to the t-case), tap ports or weld bungs to the box, braze the box to the t-case, re-install the t-case (and linkages, dirveshafts, and everything else), run coolant lines, add a large risk of a loss of engine coolant (long hoses under the vehicle, brazing onto a high-stress part,...), refill the gear oil, and not even end up with that good of cooling, conducting all the heat through one patch of the housing, and using relatively hot fluid to try cooling it... (and restricting the flow through your heater, causing it to be less effective)
    option b) zip-tie a tranny cooler with built-in fan and thermostat to it and above the crossmember, screw a little oil pump onto that, run wiring to the engine compartment (much easier than coolant hoses), screw two adapters into the t-case, add a couple feet of tranny cooler line and some hose clamps, refill, done.
    Or.... wait until you do an engine swap, and put a np205 in at the same time.
    --Randy
    If you are brazing why not just add cooling fins? My problem with taking coolant back to the t-case is the possibility of trail damage. Right I'm the middle there is a good place to get high centered or just dragged across stuff. You could put it on top but not too much room.
    $.02
    New Haven, CT
    Quote Originally Posted by BBM715 View Post
    $.02
    Water is MUCH more thermally conductive than air. The lines can be routed out of harm's way. That jacket could be put on top of the T/C. Doesn't need to be very thick, maybe 1/4" of space for coolant to flow through.
    Feb 2009
    Northern California
    The t-case is only filled a third of the way with fluid. It would need to be on the bottom. anywhere else and you're only cooling the air and the stuff slung off the gears to the right spot...
    --Randy
    New Haven, CT
    --Randy
    When the thing is running, gear oil is being splashed all over, so that doesn't matter. Also, the T/C is a big/thick cast iron box, which is very thermally conductive. Even with no oil slosh, you would be able to dissipate a lot of heat from the top.
    And that case is thick. Try it and let us know. Your fab skills dwarf mine so I'd be I terested on how it turns out.
    New Haven, CT
    Quote Originally Posted by Mikel View Post
    I'm building a NP205/200 hybrid for my 6x6, which will use two of the 200's output bearing assemblies (the most likely sources of the heat). If my 205 starts overheating, this is precisely what I plan on doing.
    I have two things in my favor:
    -4.56 gears and 38.5 tires - RPM's should be considerably lower.
    -T/C would be bolted to the transmission via a big aluminum (very conductive) adapter, acting as a big heat sink. In a M715, the NP200 sits on its own, with very little to dissipate heat elsewhere.
  1. NP200 heat idea....
    By randyscycle in forum Modified Tech
    Last Post: September 25th, 2016, 02:16 AM
  2. Another NP200 heat thread!
    By Mikel in forum Open Discussion
    Last Post: June 25th, 2015, 08:41 PM
  3. NP200 Heat
    By rboltz in forum Stock Tech
    Last Post: July 19th, 2009, 02:55 PM
  4. Confronting transfer case heat, stock NP200
    By brute4c in forum Open Discussion Archives
    Last Post: May 31st, 2007, 10:08 AM
  5. np-200 and heat?
    By boghog in forum Open Discussion
    Last Post: February 12th, 2007, 09:46 AM
