Old January 9th, 2019, 06:05 PM
JCRJ JCRJ is offline
Civilian
JCRJ is a Soldier
Default Rear swap from 90 dodge truck into m715
I recently acquired a M715, Iím also new to the forums, first timer here. I have a 1990 d350 with 6bt. Iím thinking about swapping the entire drivetrain into the 715. Has anyone ever used the Dana rears from the dodge pickup?
Old January 9th, 2019, 06:33 PM
ray steadward ray steadward is offline
Private 1st Class
ray steadward is a Soldier
Rears are pretty easy if they are wide enough to clear the spring packs....Measure between the backing plates.
Is that real money?
Old January 9th, 2019, 06:36 PM
jhartings is a Soldier
Welcome! Many Zoners have done similar swaps and itís alot of work but should be a good project. Some custom mounts and will probably have to redo the axle perches but should work. Might want to check axle width. M715 hub to hub /axle width is pretty wide.
Old January 10th, 2019, 01:51 AM
Mikel Mikel is offline
Sergeant
Mikel is a Soldier
Quote:
IIRC, way too narrow from brake backing plate to backing plate, but that's what disk brake conversions are for
Old January 10th, 2019, 04:37 AM
Civilian
JCRJ is a Soldier
So the dana60/70 in the rear of the dodge truck won’t fit under the M715? I’m measuring it all today so I’ll know by this afternoon. That will be a bummer.
  #6
Old January 11th, 2019, 09:17 AM
TXfirefighter is a Soldier
Default rear axle
I used an early '90's Dodge D-60. The WMS to WMS was great, Backing plates were wide enough but I did have to move the spring perches on each side and relocate the shock mounts.
  #7
Old January 14th, 2019, 08:45 PM
Civilian
JCRJ is a Soldier
That’s great to know. Thanks for the info.
  #8
Old March 13th, 2019, 05:03 PM
Watch your pinion angle. If you use an NP205 or other high rear output t-case you'll need to pitch the pinion up to about a 10 degree slope or more.
Mine is going to live with what I have for now and solid u-joints.
It's right on the edge of needing a double cardan joint in the shaft and that would require raising the pinion to 15 degrees.
Sent from my SAMSUNG-SM-G890A using Tapatalk
1998 - 2019
Copyright 1998-2019
