Results 1 to 10 of 14
Thread: NAPA part numbers for front and rear wheel bearings?
    Default NAPA part numbers for front and rear wheel bearings?
    Anyone know the NAPA part number for the correct wheel bearings? My -725 is in the shop to get some brake work done to it, and while the wheel seals are being replaced, in case the mechanic sees the original bearings are crap, I'd like to pop on down to NAPA and get the bearings for him. Thanks,
    It will be a lot cheaper to get them from AB Linn.
    Yes, I agree. But if the mechanic says it needs them, I can walk nextdoor and order them next day from NAPA. I am only buying them if the guys needs them, but if he does, I will need them right away.
    I just looked through the manuals and couldn't find it. I know it was listed there at one time. Jon should be along soon and he will know where it went.
    SF Bay Area, CA
    From previous posts:
    The rear wheel bearing p/n's are as follows. Timkin brg's inner cone is 469, inner cup 453X (not positive), outer cone is 368A, and I don't know the outer cup. The rear wheel bearing seal is National p/n 416282 (size 2.750 x 4.249 x .468 double lip seal) which replaced National p/n 476282-X54. There is no seal between the differential and the wheel brg's so expect to have gear oil lubing the whl brg's.
    Robert
    Wheel Bearings, Rear
    The information I have for the rear is for the bearings only. I don't have the cup numbers. Outer bearing is Timken #368A with a 2.000" bore rated at 4600 lbs.
    Inner bearing is Timken #469 with a 2.250" bore rated at 7300 lbs.The seal is a NAPA #27601. If someone has the Timken cup numbers I will add this to my
    book.
    from ed drake 18 jul 01
    SF Bay Area, CA
    From Brut4c's parts info:
    Wheel Bearings, Front
    The seals that I used for the rear,Napa#27601 The front seal # is Napa#28474 ...Leme see...The front
    bearing(outer)is Napa#BR18720....
    from Cutworm 68 #4621 10/28/99
    Outer-Timken #18790 Rated @2950 lbs.
    Cup #18720
    Inner-Timken #387A Rated @4900 lbs.
    Cup #382A
    from Ed Drake 16 feb 01
    Lone Pine, CA
    The numbers are on the bearings. Your mechanic will know exactly what to get if needed.
    Chris
    Northern Colorado
    I bought the front wheel bearing seal from NAPA for about $50. Someone here said that AB Linn had it for under $10, IIRC.
    I bet his bearings are much cheaper, too.
    I hve nothing further to add than whats been said...I would have to tear into mine to get more info...
    The bearing and race will have a number on them that can either be used as is or crossed into another manufacturer.........
    Typically, the bearing number starts with an LM
  1. New NAPA part Numbers - Master Swap
    By rboltz in forum Modified Tech
    Last Post: September 13th, 2010, 08:57 PM
  2. rjenkins : Front and rear shock part numbers
    Last Post: November 11th, 2009, 02:23 AM
  3. rear wheel bearings
    By terryb in forum Stock Tech
    Last Post: March 6th, 2007, 07:20 AM
  4. NAPA brake part numbers
    Last Post: December 24th, 2006, 04:44 PM
  5. NAPA brake part numbers
    Last Post: November 3rd, 2006, 10:11 PM
