Results 1 to 5 of 5
Thread: novak sbc vs advance sbc adapter one better??
    Default novak sbc vs advance sbc adapter one better??
    the novak and advance small block chevy adapter has a second 3 inch thick plate adapter to allow for the 10 1/4 inch input shaft from the t-98 trans and advance also offers a second adpater that comes with a 7.75 inch input shaft with 17 teeth gear to change out the t-98 trans 10 1/4 inch shaft . my thoughts are which is better the novak allows the chevy engine to move forward away from the firewall for more distributor clearance but does this change the clutch linkage . the advance adapter has the 7. 75 inch input shaft to change out the 10 1/4 inch input shaft but does this change the clutch linkage . also the novak calls for a 4 11/16 inch ring vs a 5 1/2 ring for the chevy bellhousing what is this ring for exactlly . so does the adapter from novak and advance that has he second 3 inch plate allow the clutch linkage to stay in the same place with new new chevy bell housing or does the advance adapter with the 7 3/4 replace input shaft allow the clutch linkage to stay the same with the chevy bell housing ???
    Washington State
    I would call Novak and or AA to find out your question. If you used a hydraulic clutch setup you wouldn't have to worry.
    Richboro,Pennsylvania
    Go hydro and call it done. No fussin with linkage. Use a CJ master if you can't find a stock Gladiator master. Just make sure the piston sizes match.
    Washington State
    I used a hydraulic master and slave from a 1986 xj. Very straight forward, might have to build a bracket to mount the master off the firewall, and a bracket to mount the slave off the bellhousing. Other than that it wasn't that difficult.
    I have the Novak with the clutch adapter piece for the mech linkage, works fine and no worries about the cylinder going out while im running around, I suppose if your hardcore off roading the hydraulic set-up would be better but for daily driving and trail running I would stay with the mech set-up less modifications as well.
    just my .2
  1. Vacuum Advance
    By rpgdeity in forum Modified Tech
    Last Post: February 27th, 2011, 06:23 PM
  2. Novak or Advanced?
    By jay r in forum Modified Tech
    Last Post: January 11th, 2010, 09:21 AM
  3. rpgdeity : Vacuum Advance
    Last Post: November 11th, 2009, 12:01 AM
  4. vaccum advance question
    By jpsnblood in forum Stock Tech
    Last Post: July 14th, 2009, 12:31 AM
  5. ATTN: Novak Adapter Users
    By smartybritches in forum Modified Tech Archives
    Last Post: April 10th, 2004, 11:21 PM
