Results 1 to 5 of 5
Thread: BBC header?
    Jul 2008
    Saginaw Michigan
    Default BBC header?
    What headers fit the 715 with a BBC? I am thinking the mid 80's chevy truck will work but just want to make sure before I spend some big bucks on headers.
    Really kind of depends on how you want to run your clutch and exhaust. Block huggers work great. So do stock cast iron manifolds for the most part.
    You have two basic choices for the exhaust. Outside the frame on both sides or cross over to the passenger side under the cab and have dual exhaust on that side or all into one. The fuel tank gets in the way is why you have to make this choice.
    Jul 2008
    Saginaw Michigan
    I was looking at block huggers but I am building a pretty big motor, upwards of 600 hp and tq. I dont want to be restricted by the headers. I will probably have the gas tank in the back of the bed and I am using a T400 for a tranny.
    if you look in my build thread titled "found one" in the open disscusion area, there are pictures of my exaust as i routed it and somewhere in the thread are pics of my headers. they are hooker comps or super comps i cant remember which, but they are for 72 chevy 4x4 with a BBC swap. they fit rather well, i had to modify the #6 tube but it was easy and depending on how you position your engine that may not be an issue. it also has a manual with a clutch, but it is hydralic. since the truck is set up much like a chevy and uses mostly all chevy driveline stuff it all worked fine. the exaust was not that fun to make, but i cut and pasted out of mandrel bends. i also have a fuel tank in the stock position and the exaust is all above the frame for the entire run. it is 2 1/2" into a single 3. it may have been doable with 3" into a 3.5" or 4" the way i did it, but it would be tight.
    67 #18820 mostly stock...
    Jul 2008
    Saginaw Michigan
    Thanks Ryan, thats the info I was looking for. I am lucky enough to have an Exhaust shop in the family that can bend up a custom exhaust for me once I get everything bolted together.
  1. 230 Tornado Header Flange
    By rpgdeity in forum Modified Tech
    Last Post: October 31st, 2012, 05:20 AM
  2. elohim1 : BBC header selection, what did you use?
    By Elohim1 in forum PseudoZone - Mod Tech Archive
    Last Post: December 15th, 2009, 07:48 PM
  3. New site header
    By compexp in forum Forum for questions and comments on the website.
    Last Post: April 3rd, 2009, 11:42 AM
