Results 1 to 8 of 8
Thread: bluesman2a : New Lines...
    Atlanta, Ga.
    Default bluesman2a : New Lines...
    New Lines...
    Post by bluesman2a on Jun 18, 2006, 7:55pm
    Quality double-flaring tool: $100
    Quality bending tool: $20
    Bulk stainless line (25 feet): $25
    Getting your lines to fit exactly the way you want, and not having to wait for them: PRICELE$$
    Being able to go back and repair/replace any section at will for future maintenance with my own tools: EVEN MORE PRICELESSER!!!
    Default k8icu :
    Re: New Lines...
    Post by k8icu on Jun 18, 2006, 9:16pm
    Running an automatic trans? Nice work! $1 a foot wow not cheep, but not outrages either.
    Atlanta, Ga.
    Re: New Lines...
    Post by bluesman2a on Jun 18, 2006, 9:30pm
    Yep, running a TH400. You can get the stuff cheaper, but I prefer stainless which lasts longer, but is more of a premium. It's also a little harder to work. BUT it's down right durned-economical when you price it against pre-bent lines that are store-bought. When they gave me the price, I asked if the lines came with a new TRUCK too!!!
    Washington State
    Default fisherman :
    Re: New Lines...
    Post by fisherman on Jun 18, 2006, 10:26pm
    Nice work. I think I will be going that route as well. I like to do as much as possible, also gives me a chance to go buy some new tools. Fisherman
    Default robertcowan :
    Re: New Lines...
    Post by robertcowan on Jun 18, 2006, 10:51pm
    i,d recomend getting a chraftsman flairing kit. rigid makes a super nice set of tube benders. both gauranteed for life. get a double flair setup too !
    Northern Colorado
    Default fsjguy :
    Re: New Lines...
    Post by fsjguy on Jun 19, 2006, 12:03am
    Looks REAL nice. A lot better than my POS bending jobs. I redid my fuel lines with brake line a while back. Before, it was a cobbled together mixture of metal and rubber lines. Kinda scary.... Not wanting a Car-BQ, I replaced em so the only rubber lines are short and easily inspected and replacable.
    Default bigwheelbob :
    Re: New Lines...
    Post by bigwheelbob on Jun 19, 2006, 7:08am
    Just for general info for everyone, Snap-On has a new bender out that will bend the small brake lines 180 degrees. It is the coolest one I have seen yet. I have used the above bender for years, and it is very easy, and does a overall great job, but sometimes you need it a little tighter. Also, Snap-On seems to have the best double flair kit also, I have wore out many other brands to the point the lines just slip thru when you crank down on the flair. Believe it or not, neither Snap-On piece is overly pricey.
    Default barrman :
    Re: New Lines...
    Post by barrman on Jun 20, 2006, 9:47am
    Nice work!
  1. Vacuum lines
    By fng in forum Stock Tech
    Last Post: May 12th, 2014, 03:12 PM
  2. brake lines
    By henry715 in forum Open Discussion
    Last Post: March 6th, 2010, 05:14 PM
  3. bluesman2a : Speedo Recommendation.
    By bluesman2a in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 03:12 AM
  4. Vacuum Lines
    By ochartman in forum Stock Tech
    Last Post: February 12th, 2009, 01:19 PM
  5. Last of the vent lines
    Last Post: May 1st, 2007, 06:23 PM
