Results 1 to 6 of 6
Thread: binfordm715 : Stock Dana 70 vs. 14-bolt clearance issues
    Port Orchard, Wash.
    Default binfordm715 : Stock Dana 70 vs. 14-bolt clearance issues
    Post by binfordm715 on Aug 28, 2006, 1:22am
    Any idea how tall the diffs are between these two axles? What I'm wondering about is the distance from the spring plate (or top of the leaf spring) to the top of the diff on a 14-bolt.
    The reason I'm wondering is to make sure a 14-bolt would still clear Fisherman's modification to fit an XL in the stock spare tire location.
    Default jeepistdougiowa :
    Re: Stock Dana 70 vs. 14-bolt clearance issues
    Post by jeepistdougiowa on Aug 28, 2006, 1:26am
    The rear axle is already SUA, I can't think of any reason it would be any different than the 70??
    Default tacomainoh :
    Post by tacomainoh on Aug 28, 2006, 1:29am
    If it is, it's not by much. I'll take some measurements tomorrow, but they will likely be unnecessary: they are very close to the same size. At one point I did actually measure them side by side, but didn't write nothin' down, mang.
    Atlanta, Ga.
    Default bluesman2a :
    Post by bluesman2a on Aug 28, 2006, 11:05am
    I can't comment on Fisherman's project, but I can tell you that I tried to put a 16" deep fuel tank DIRECTLYT behind the rear cross member with no diff clearance issues on my 14 bolt. Also note my diff cover sits 1/2 to 1" further back than normal (extra beef).
    Default robertcowan :
    Post by robertcowan on Aug 28, 2006, 11:10am
    WITH A 14 BOLT I BELIEVE YOU,LL HAVE DRIVE SHAFT TO FUEL TANK CLEARENCE PROBLEMS AS THE PINION IS SET OVER CLOSER TO THE DRIVER SIDE OF THE TRUCK.
    Atlanta, Ga.
    Post by bluesman2a on Aug 28, 2006, 11:20am
    Yep, had to pull my stock tank. Pic:
    Note: the shaft is larger than normal, 1410 joints and I think a 3"+ tube.
  1. DRW Dana 60 / 14 Bolt
    Last Post: November 9th, 2008, 10:16 PM
  2. 14 bolt versus stock dana 70
    By BCOWANWHEELS in forum Open Discussion
    Last Post: February 9th, 2007, 06:45 PM
  3. Stock Dana 70 disc brake and 8 on 6.5 lug pattern conversion
    By PaulC in forum Modified Tech Archives
    Last Post: April 20th, 2004, 12:35 PM
