Results 1 to 7 of 7
Thread: Hood Latch
    While looking at Brians pictures on the BS board, I notice that his hood locating pin is on the drivers side. Mine is on the passenger side. Somebody posted a bunch of pictures and text a while back about putting lights in those recesses because his has no locating pins. What is the stock set up? Do they matter at all?
    Northern Colorado
    I still have a hood locating pin. If you look at a civilian FSJ, you will see all sorts of hood latch hardware. That is where I put the engine bay lights. Someone else will have to clue you in to the stock setup, as I have a J truck header panel on mine. (to fit the civilian radiator which fits the AMC360)
    parsons Kansas
    Ill check on mine and post it tonight.
    67 M725, 67 M715, 68 M715
  4. Default
    Mines on the passenger side.
    1969 M715
    passenger side.
    Big Blocks RULE!
    Default Swapping in M715 axles
    I get that means that Brian probably took his off and put it back on the wrong side. Thanks for the information.
    Man, you could have just asked me.
    I went to Memphis Equipment and got a 2nd one. When I replaced my hood, the hood came with the civvy latching stuff and it was made for 2 pins. I got the 2nd one just to make it all work right, even though there was no need for it, nor any advantage. I just wanted it evened up.
    The hood never vibrated or shook or anything like that- I just added it.
    Stock is 1 post on the passenger side. No inner hood latch.
    Riddle me this- if you have a custom tailgate then why do you still want my old non-stock one? Not to 2nd guess you, but if you have a decent one then you're not gonna want this one. I promised it, so it's yours anyhow- I was just curious.
  1. Civilian hood latch
    By george walker in forum Open Discussion
    Last Post: March 8th, 2018, 04:33 PM
  2. Tool Storage Box Latch Question
    By BlessedM715 in forum Stock Tech
    Last Post: November 27th, 2009, 12:31 AM
  3. teking : How to turn a 78 J hood into a 67 M715 hood
    By teking in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 12:06 AM
  4. Old New Stock Hood or Wagoneer / J truck hood
    By CrashMorriss in forum Stock Tech
    Last Post: July 7th, 2009, 09:35 AM
  5. Pics of FSJ hood latch
    By SHoppe in forum Modified Tech
    Last Post: April 5th, 2008, 08:34 PM
