Results 1 to 10 of 18
Thread: my new motor
    Default my new motor
    I now have a 12 cylinder 36 valve cummins in my dodge It is the new motor for my 715. now I need to find a 3053a tranny to mount to it. Has anybody done this yet, I have read lots about it but I can't find what I need to mate the two.
    Last edited by Binford; December 8th, 2007 at 03:39 PM. Reason: Reduced picture size
    Holy huge picture Batman! You are going to have one heck of a driveline!
    sorry about the size of the pic, I didn't know it would be that big
    Its a standard sae bell,I wouldn't think it would be too hard to match up. If you can't find a trans near you, I be I can get one for ya.
    Jan 2007
    Georgetown, CA
    Is that a typo, . . 12 cylinders and 36 valves????, ..tell me you meant a 24 valve? I am trying to picture 12 cylinders in a M715, . . . sounds like a great plan though
    I agree is that thing going to fit with out using a shoe horn and putting the firewall 2 inches from the front seat... ?
    Zone holster maker
    This is the same set-up i am going to run. You will need a SAE #3 bellhousing and as far as i know a clutch set-up from a F-750 will work as well. Here is a link of a guy that put a 3053a behind his cummins in his 1 ton dodge truck.
    http://www.dieseltruckresource.com/d...t=92060&page=2
    Here is another link from JP magazine of them installing a 3053a in a 715 behind a SBC, they also have most of the part numbers from NAPA that you will need.
    http://www.jpmagazine.com/techarticl...ion/index.html
    This guy has 3053a's that are take out's for $350. He can also get you a flywheel and clutches. He will assist on shipping as well. jepcolwell@aol.com
    Good luck and let me know how it goes, i purchased a 96 6bt a few months ago for mine and have found a guy very close to my house that recently won a GL auction with many 3053a's in it. I am waiting to see if the tranny's he has won are any good. A guy buy the name of SPICERGEAR over on SteelSoldiers has a BBC with a 3053a behind it in a 715 and a guy by the name of M35-TOM on SS is making taller overdrive gearsets for the 3053A, but they are pricey. Around $1,200 for a set.
    Quote Originally Posted by moosejr View Post
    I was talking about the dodge. The 24 valve in the front and the 12 valve on the back. The 12 valve is out of a '95 and is the new engine for my 715.
    Quote Originally Posted by gun512 View Post
    Thanks for the links gun512. I guess I also need to look for a larger flywheel and clutch. Or a wrecked big ford or FL70.
    A guy on TDR said he has seen several 3053 torn apart by hopped up 5.9s. Anybody else heard of this? I don't plan on going to wild with the 5.9 maybe a #10 plate, but I would like to know this trans will hold up if I do turn the cummins up.
  1. elohim1 : Which 502 motor should I use?
    By Elohim1 in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 04:46 AM
  2. New motor?
    By k8icu in forum Open Discussion
    Last Post: April 17th, 2009, 11:43 PM
  3. How to set the motor RPM
    By sf38a1 in forum Stock Tech
    Last Post: June 12th, 2008, 12:54 PM
  4. Wiper motor
    By Kamikaze12volts in forum Stock Tech
    Last Post: March 17th, 2008, 03:55 PM
  5. Motor choice-
    By Brian Sisson in forum Open Discussion Archives
    Last Post: January 30th, 2004, 05:47 AM
