Results 1 to 2 of 2
Thread: Hard Top Insulation
    Default Transmission Cross Member
    As some of you may have read, I just filled in all of the fire department drilled holes, filled all of the rivet holes, stripped, painted and put new glass in my metal hard top. Before I put it back on the truck, I also insulated it. I used the heat shield mat that JC Whitney sells. I only had enough to do the back vertical part around the window. Even with the complete top surface waiting for the UPS truck to bring me more, I can tell a tremendous difference in noise. It no longer feels like I am inside a coffee can rolling down a hill.
    I didn't expect this big of a difference. I was looking more for thermal insulation. I can only imagine what the difference would be with the entire top done and thick, thick bedliner applied to the cab tub.
    Albuquerque New Mexico
    Insulation does help. Last weekend I installed a "headliner" I made out of some masonite into the hard top. I added some foam rubber between the headliner and top mostly to help pad the new dome light I added but it helped with noise too.
    Stan
  1. Hard top value?
    By kingjason in forum Open Discussion
    Last Post: December 16th, 2009, 10:31 PM
  2. Hard Starting
    By axeman in forum Stock Tech
    Last Post: December 13th, 2009, 11:25 AM
  3. Hard top
    By chicklin in forum Open Discussion
    Last Post: January 13th, 2009, 08:54 PM
  4. Hard top
    By BulletSponge in forum Modified Tech
    Last Post: April 17th, 2007, 06:59 PM
  5. Spray on Insulation
    By Barrman in forum Modified Tech Archives
    Last Post: May 3rd, 2004, 04:49 AM
