Here are some pictures of the Stainless Steel tank I am in the process of making. It is designed to be very similar to the stock tank. Overall it is about 1 inch narrower, same height and same length. I ran the baffle from side to side, the stocker is front to back which only makes sense for production, not function. I am replacing the sending unit with a universal unit.
I just picked up the SS tube for the filler, and a new bottle of gas for the welder so I hope to finish it tonight. I will put up a few more pictures then.
I am lining it with POR Gas Tank liner before I weld on the top, and will be covering the outside with a DIY Bed Liner like Duraback before the install. It mounts just as the original did.
I have enough material to make 1 more, if there is interest. It took about 2 full days and the material costs alone are about $300-$350.
