Results 1 to 7 of 7
Thread: fisherman : Cab and Bed Mounts
    Washington State
    Default fisherman : Cab and Bed Mounts
    Cab and Bed Mounts
    Post by fisherman on Oct 29, 2006, 12:17pm
    Someone posted awhile back about using boat rollers and cutting them for their body and bed mounts. I want to do 1" over stock body lift and I think this would work great. I did a search and nothing came up. Any Information would be appreciated. Thanks All
    Default gimpyrobb :
    Re: Cab and Bed Mounts
    Post by gimpyrobb on Oct 29, 2006, 12:49pm
    I thought it was Lucky, but he's in death valley right now.
    Default bigwheelbob :
    Post by bigwheelbob on Oct 29, 2006, 2:36pm
    Boat rollers? UGH!!!!!!!!! Try CJ style mounts.
    Washington State
    Default fisherman :
    Post by fisherman on Oct 29, 2006, 4:16pm
    Will cj style mounts give me some body lift?
    Default kwai :
    Post by kwai on Oct 29, 2006, 6:27pm
    I used the boat roller method and they work fine. I don't know how they compare to CJ mouts for hardness. Problem with raising the bed mounts using more rubber is the added load on the bolt and spacer when loaded. Could try aluminum or steel spacer under the existing mounts with longer bolts.
    Default grantshire :
    Post by grantshire on Oct 29, 2006, 8:17pm
    I used this method a couple of years ago to build a 1.5" body lift for my 74 Wagoneer Custom. Used the boat rollers with the nylon sleeve insert. Pull the sleeve out; cut them to your desired thickness; go to the hardware store/Home Depot and buy steel tubing same diameter as sleeve; cut the tubing about 1/2" shorter than mount; buy the right length grade 8 nuts & bolts with 2 large washer; and bolt it up. Works great, is inexpensive and the sleeved body mounts are really stable. I did a write up with pictures on this over on the IFSJA site, but you'll have to do a search for it because I did not save the link.
    Default k8icu :
    Post by k8icu on Oct 29, 2006, 9:32pm
    I think Luck was doing some Poly rasamataz type mounts. Latest and greatest so to speak.
  1. fisherman : Those of you with Benders
    By fisherman in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 05:05 AM
  2. fisherman : Gauges
    Last Post: November 11th, 2009, 05:33 AM
  3. fisherman : More Pics
    Last Post: November 11th, 2009, 03:13 AM
  4. fisherman : Pic posting again 3rd try
    Last Post: November 11th, 2009, 02:05 AM
