  #1
Old March 26th, 2020, 08:41 AM
Nomad's Avatar
Nomad Nomad is offline
Civilian
Nomad is a Soldier
Default Tire choice
Which do you guys think will be a better option for tires. I plan on doing around town driving, dirt roads, nothing to crazy.
Seating these on factory rims.
I found a new set of 9.00x16 SPECIALTY TIRES OF AMERICA STA MILITARY NDS x4 for $1098.17 shipped.
https://simpletire.com/specialty-tir...16-ln18e-tires
I also found a set of 9.00r16 Michelin xzl takeoffs with a dot date of 2006-2011 at 75%-90% tread x4 shipped for $1,030.37
My concerns are the dot date of 2006-2011 on the xzls. What do you guys think would be the better option here?
  #2
Old March 26th, 2020, 11:44 AM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
I think my XZL tires are dated 2001 or 2003. I was going down the road at Warp speed (52 mph) the other day just as smooth as can be. I have no visible cracking on the sidewalls yet.
If you do go with the XZL tires keep them pretty aired up. I had a set of XL tires on my Whistler M35 and one sidewall just ripped all the way from the bead to the tread. I only had 25 psi in there and a load on the bed. Others with those tires report the same thing. If the sidewall is flexing and you see cracks. Either air up or start buying new tires.
The new NDT tires are really tempting. Lighter, small, less rolling resistance, comparable off road when aired down and figure another 20 years of life left in them. What they don't give you is the rubber overdrive of 12% more speed that the Michelin tires do.
__________________
1998 - 2020
Copyright 1998-2020
