Thread: dummy : Front shackle dimensions?
    Default dummy : Front shackle dimensions?
    Post by dummy on May 28, 2006, 9:25am
    Over2land tells me the front springs are 2.5-inches wide (my truck is 150 miles away or I'd measure myself). I need some front shackles to replace some cobbled abortion a previous owner affixed to the front springs as a lift attempt.
    What's the id of the front shackle hanger? I remember hearing somewhere that stock XJ shackles would work.
    I'm trying to get this pig ready for the FSJ deal in Ouray in July.
    Default dummy :
    Re: Front shackle dimensions?
    Post by dummy on May 28, 2006, 9:39am
    http://img83.imageshack.us/my.php?im...2480img7ml.jpg
    Default binfordm715 :
    Post by binfordm715 on May 29, 2006, 11:46am
    The id of the lower portion (where the springs go) is 2-3/4" and then it tapers down to 1-7/8" at the point it mounts to the frame. Both sides taper evenly. That is to say, both sides come in 7/16".
    That pic looks pretty hacked. Let me know if you'd like a similar pic of what it's supposed to look like.
    Oh, and the top spring width is indeed 2-1/2" wide. The other springs in the pack are 2".
    Default dummy :
    Post by dummy on May 31, 2006, 9:19pm
    Cool. I'll just make some shackles myself then.
    A pic would be great if you've got the stock setup. Thanks.
    Default kwai :
    Post by kwai on May 31, 2006, 10:21pm
    You can still get NOS front shackles from AB Linn, Memphis, VPW, etc.
  1. dummy : Running 12V AND 24V????
    Last Post: November 11th, 2009, 03:57 AM
  2. Dummy needs wiring help.
    Last Post: February 25th, 2009, 10:47 PM
  3. Need pic and dimensions of PTO linkage arm
    By Duane in forum Stock Tech
    Last Post: August 17th, 2008, 09:14 AM
  4. What are the dimensions of the correct Pitman Arm?
    By Binford in forum Modified Tech
    Last Post: April 4th, 2008, 08:27 PM
  5. Can someone please give me some dimensions?
    By amphi in forum Modified Tech
    Last Post: March 12th, 2008, 09:13 PM
