Results 1 to 10 of 14
Thread: tilt front end
    Default tilt front end
    has anyone done a tilt front clip on a 715 and if so can you post some pics thanks for the help
    I have seen this:
    Is this the same truck that Barry had the cowl induction hood?
    anyone know if the wheels are stock M35?
    any guess on the tire size?
    1100 x 20 XLs?
    "An axe. A real axe. An 'I'm out of ammo, let me grab the axe', type of axe!" steelsoldier FrankUSMC
    This is not the truck he had the cowl induction on.
    Those are definitely Rockwells, and look like stock Deuce wheels just flipped on the front.
    I had thought of doing this in the distant future. I think the hardest thing to do would be radiator, making it secure enough for off road.
    That would be handy....nice fab
    Jan 2007
    Georgetown, CA
    Securing the radiator really would not be that difficult, just build a support hoop like on a race car, . anchored to the frame, and then trim the mount points on the core support to prevent interference. What I have found with tilt front-ends, is that that they sound better in theory than in practice. You can't mount anything to the inner fenders, everything has to be mounted either to the firewall or by fabbing mounts to the frame. You really have to do a good job of framing the sheet metal, because it is designed to be integrated into the other structures, so if it is not framed well, it will rip itself apart. . . .
    Other than the wow factor and unfettered access to the engine on occasion, tilt front ends don't really seem too practical as Moose mentioned above.
    My sheet metal flexes enough off road as it is, with new body mounts and bolts and everything functioning properly. I'd hate to see what it would look like unsupported.
    Yes to the 11.00-20
    I think they are the stock M34 rims compared to M35 rims. The bolt flange is about 2" more inside the can on the M34 rims.
  1. Show me your Tilt Steering Columns
    By CrashMorriss in forum Modified Tech
    Last Post: October 30th, 2012, 11:26 AM
  2. tilt wheel from civ. jeep (non fsj)
    By pamuddyjeep in forum Modified Tech
    Last Post: September 23rd, 2007, 03:13 AM
  3. CJ Tilt column?
    By alosix in forum Modified Tech
    Last Post: April 16th, 2007, 04:52 PM
  4. tilt steering???
    By soupy in forum Modified Tech Archives
    Last Post: March 25th, 2004, 12:34 PM
  5. Tilt Front
    By Nuke_M1028 in forum Modified Tech Archives
    Last Post: January 18th, 2004, 06:23 PM
