Results 1 to 9 of 9
Thread: gimpyrobb : np 205
    Default gimpyrobb : np 205
    np 205
    Post by gimpyrobb on Aug 16, 2006, 8:38am
    Last night I got the 366 out of my donor c60. After I get the trans and winch off it, I will be preping for the swap into the Kaiser. I am trying to line up a divorced 205. There is an 80 power wagon near me for 400.00. When did Dodge go to a married xcase? The owner doesn't know what I'm talking about and I'm short on time to go investigate. Thanks up-front.
    Default barrman :
    Re: np 205
    Post by barrman on Aug 16, 2006, 8:49am
    I "think" it was around '77. But, I am not sure. Have him crawl under and look.
    Default gimpyrobb :
    Re: np 205
    Post by gimpyrobb on Aug 16, 2006, 9:05am
    From some research it looks like it was a transition year and it could be a 205 or 208. I guess I'll have to make time to check. Anyone need parts from this truck?
    Default elwenil :
    Re: np 205
    Post by elwenil on Aug 16, 2006, 9:31am
    An 80 most likely has a NP203 fulltime mated case. Divorced case stopped with the '75 model year.
    Default gimpyrobb :
    Re: np 205
    Post by gimpyrobb on Aug 16, 2006, 10:02am
    Thank you sir!
    Default kwai :
    Re: np 205
    Post by kwai on Aug 16, 2006, 12:16pm
    Show him a pic of a 205 and ask him if it looks like that. Or have him send you a pic.
    Default elwenil :
    Re: np 205
    Post by elwenil on Aug 16, 2006, 12:36pm
    Eh, from the back 203s and 205s look pretty similar, but from the front you can easy spot the huge gearbox on the front of the 203.
    Default oilcan :
    Re: np 205
    Post by oilcan on Aug 16, 2006, 12:42pm
    Even easier to spot the 3rd drive shaft of a divorced unit.
    Default tacomainoh :
    Re: np 205
    Post by tacomainoh on Aug 16, 2006, 1:45pm
    The 203 also has an enormous differential bolted to the back of it.
  1. gimpyrobb : Master cylinder
    By gimpyrobb in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 04:32 AM
  2. gimpyrobb : Steering issues
    Last Post: November 11th, 2009, 02:25 AM
  3. gimpyrobb : Thinking about a cucv
    Last Post: November 11th, 2009, 01:39 AM
  4. gimpyrobb : Towbar
    Last Post: November 11th, 2009, 01:29 AM
  5. gimpyrobb : towbar brackets
    Last Post: November 11th, 2009, 12:37 AM
