Does anyone have or know where i can see a schematic of the entire vent system including the route taken by each line and where they go from steel line to hose. thanks
Not really....we have a chart to show the basic routing of the vent lines and which ones run together. There are 2 different versions as there was a big change during production from a carb mounted air cleaner and no governor setup to a governor equipped unit that required a canister air cleaner that bolts on brackets to the underside of the hood.
The diagrams are in the Online Maintenance Manuals section, linked above...or directly linked here:
Early, carb mounted aircleaner/no governor:
http://www.m715zone.com/vb/view.php?pg=early_vent
Late, Canister air cleaner/with governor:
http://www.m715zone.com/vb/view.php?pg=late_vent
Thanks for quick reply, but that helps very little unfortunately. Many of my steel lines are missing, and i need to know where they came from and where they go to, and the shape ect... I appreciate it - Roger
Roger, what type of air cleaner are you running? Canister or regular. If canister, I'll go out to my truck with a camera and take some pics for you. If non-canister, I can't be of much help.
Zach
