Results 1 to 8 of 8
Thread: radiator questions
    Apr 2007
    new pal, indiana
    Default radiator questions
    hi guys, i recently got a m715 and it has some overheating issues, it has a bbc in it and i think that it has the original radiator from the 6 cyl in place, so i am sure that this may be the root of my problem. my question is, does anyone know of a big radiator that will fit without major surgery? there is also an electric fan that does not cover the entire radiator surface (close to 60%) so this may be an issue as well. i did read the post about the elec fans, so i might be looking for one of these.
    Mar 2004
    northern Arizona
    I used the flex-o-lite black magic fan on a '68 chevelle radiator - designed for a 396. I don't have the p/n here at work, but you just have to trim the front mounting channel and it slides right into place.
    I can post pics tomorrow if you want them.
    67 M725 67 M715 68 M715
    Rich, its a Modine 289 and it fits the 66-67 Chevele 396, among others....in 68 they went to side tanks...
    Mar 2004
    northern Arizona
    yep, that was it.
    Apr 2007
    new pal, indiana
    thanks guys, thats exactly what i needed
    Oxford, Ohio 45056
    I used a Flexalite with My BBC. Runs about 210 degrees.
    i have a 454 in my truck and i have the stock radiator for now with two (perma frost) 12'' electric fans that pull 3000 cfm's apiece. and i have no problem with cooling as of yet. it has not gotten over 190 while running.
    M715,s..are a mans jeep...
  1. stanman : radiator questions
    Last Post: November 12th, 2009, 05:26 AM
  2. radiator
    By Treepusher in forum Modified Tech
    Last Post: February 1st, 2007, 08:35 AM
  3. Radiator questions
    Last Post: December 24th, 2006, 04:20 PM
