  #1
Old August 26th, 2019, 02:12 PM
ColoradoSpringsRob's Avatar
ColoradoSpringsRob ColoradoSpringsRob is offline
Private
ColoradoSpringsRob is a Soldier
Default Parking brake anchor spring/bolt
Silly to even ask this, but does anyone have pictures of the anchor bolt/spring combo, and can you provide dimensions?
My truck came without the band, and I am getting everything back together, and these are the last two things I need.
  #2
Old August 26th, 2019, 03:13 PM
jeepdan's Avatar
jeepdan jeepdan is offline
Sergeant
jeepdan is a Soldier
Give me 10 or 15 minutes and I will get a photo and measurements for you.
  #3
Old August 26th, 2019, 03:55 PM
jeepdan's Avatar
Sergeant
Here is a photo, measurements in a minute.
You can see from the burned paint on the drum, where I have forgotten the park brake a time or two
  #4
Old August 26th, 2019, 04:01 PM
jeepdan's Avatar
Sergeant
The J bolt is 7/16" dia. with an over all length of 6 3/8". Length of threaded area is 2 3/8"
The little anchor bolt with the fillister screw head is 1/4" dia.-- 2 3/4" length under the head.
  #5
Old August 26th, 2019, 08:36 PM
Private
Jeepdan, thanks man!
The anchor bolt and spring are located on the other side of the band...and that is what I am after. Know anything about those? If the image uploaded, I circled where the anchor bolt and spring live.
  #6
Old August 27th, 2019, 05:23 AM
jeepdan's Avatar
Sergeant
Oh, OK.
Let me look under there today with the camera, and try to refresh my memory on that one.
I'm pretty sure that it is just a regular bolt (cap screw) that has had a hole drilled crossways through the head for a safety wire.
  #7
Old August 27th, 2019, 08:57 AM
Private
I am thinking you are exactly right there on the bolt. I bought a spring at Ace that I thought looked 'right', but it is not...so I may need to go to Surplus Jeep and get one for $5 plus shipping, sigh...
  #8
Old August 27th, 2019, 11:46 AM
Private
I caved and called Surplus Jeep and ordered the spring ($5). Now I have to figure out the bolt dimensions, and drill the hole.
  #9
Old August 27th, 2019, 05:07 PM
jeepdan's Avatar
Sergeant
Good call. I bought a few from them also. I decided to get a few spares.
I guess that I really can't give you more accurate details about the bolt without taking my park brake apart.
For what it's worth, the hex head is a 1/2", so it's probably 5/16" bolt and fine thread for finer adjustment on the band clearance.
Remember, it's primary purpose is to act as a spring guide, adjust the band, and to hold the band from slipping off of the cast iron mounting lug. The mounting lug would take the rotational force.
I can't remember if the bolt hole is counterbored for the spring.
Had to throw in an extra photo just to show off.
  #10
Old September 3rd, 2019, 03:09 PM
Private
One more thing...
I think I would be ok eating off of any part of your truck.
Amazingly clean. You are an inspiration.
1998 - 2020
Copyright 1998-2020
