  #21
Old January 30th, 2016, 06:12 PM
glenn glenn is offline
Sergeant
glenn is a Soldier
Tell me more about your caliper adapters and high steer arms. Interested in them for my axletech axles.
  #22
Old January 31st, 2016, 05:51 AM
defbob's Avatar
defbob defbob is offline
Private 1st Class
defbob is a Soldier
Black Rock Fab makes them. They use an '05 Dodge 2500 caliper. The rotor has to be turned down to 15". He also makes a bracket to use F750 calipers, but I didn't want to use the huge master cylinder required for those.
The high steer arm is just a pass arm for a crossover steering. It is the appropriate length for my '12 Ram 3500 steering gear I am going to use. It will be tapered for a Chevy draglink end.
1968 M715
1968 M725
  #23
Old January 31st, 2016, 05:58 PM
md1970 md1970 is offline
Corporal
md1970 is a Soldier
wow aluminum rims ???? super duper. this will cut a lot of weight............
  #24
Old January 31st, 2016, 07:03 PM
defbob's Avatar
Private 1st Class
defbob is a Soldier
Rims are 60lbs/ea
1968 M715
1968 M725
  #25
Old February 1st, 2016, 04:21 PM
defbob's Avatar
Private 1st Class
defbob is a Soldier
Here are the caliper brackets
1968 M715
1968 M725
  #26
Old March 2nd, 2016, 07:48 AM
Troop ISP's Avatar
Troop ISP Troop ISP is offline
Corporal
Troop ISP is a Soldier
Nice seeing you building another M715. I really miss mine -last seen at an exotic car dealership in Miami.
I watched your build on Pirate of your MB. I am amazed how fast you are from one build to the next. It takes me a couple hours just to figure out how I want to do the next step.
Anyway, I look forward to your build.
  #27
Old March 4th, 2016, 05:52 PM
defbob's Avatar
Private 1st Class
defbob is a Soldier
I can't help but plot out 3 projects ahead. Usually I have the entire vehicle sorted out in my head before I begin. It helps me keep from excessive spending, or maybe it creates it... Hmm
1968 M715
1968 M725
  #28
Old May 10th, 2016, 05:34 PM
defbob's Avatar
Private 1st Class
defbob is a Soldier
I designed on Autocad some spring perches and spring plates to make the Axletechs a bolt in deal to my M715 with out doing a shackle flip. Black Rock Fab has my drawings and will be making them for me.
I am not sure how well the springs will do with the tall perches or how long the rear leaf spring studs will last with the weight of the Axletechs...
1968 M715
1968 M725
  #29
Old May 10th, 2016, 05:36 PM
defbob's Avatar
Private 1st Class
defbob is a Soldier
I also picked up an aluminum Chevy truck bellhousing for when I do my V8 swap
1968 M715
1968 M725
  #30
Old May 12th, 2016, 12:13 PM
venominjected's Avatar
Corporal
venominjected is a Soldier
Quote:
Sure hope your planning LS....
