Old August 18th, 2019, 04:03 PM
Kacz7895 Kacz7895 is offline
Civilian
Kacz7895 is a Soldier
Default Brake help
I have a 68 m725 trying to get it road worthy. In the process of doing the brakes got the rear brakes off and got some questions I tried using the search function but it won't let me type anything in. So here are the questions I jave.
I think the master cylinder is not working is there a replacement or an alternative one to get.
Can I get brake shoes for it. If so what are the part numbers. O read over on steel solider they are hard to come by and can I use gladiator brake shoes.
Also the wheel cylinders need some of those too.
Any help guidance would be freaking awsome.
Old August 18th, 2019, 05:29 PM
lelant's Avatar
lelant lelant is offline
Basic Trainee
lelant is a Soldier
Check Memphis or Boyce equipment for the parts you are looking for.
Old August 18th, 2019, 07:32 PM
jeepdan's Avatar
jeepdan jeepdan is offline
Sergeant
jeepdan is a Soldier
Quote:
Yes, Memphis Equipment has everything that you could need.
That said, A highly recommended safety upgrade is changing to a dual master cylinder.
The Dorman #56193 is an easy "bolt on" upgrade. You will need to change around the brake lines slightly to separate the circuits front/rear.
You can see from this picture of mine, how the brake lines are rerouted.
If I were you, I would replace every steel line anyway.
Old August 19th, 2019, 06:59 AM
Civilian
Thanks guys. I planned on replacing the brake lines blew some air through them and some very nasty crap come out.
Again thanks for the info
Old August 19th, 2019, 03:58 PM
Civilian
Another question can someone tell me the thickness of the new brake shoes
  #6
Old August 20th, 2019, 01:29 PM
kwai's Avatar
kwai kwai is offline
Sergeant
kwai is a Soldier
And use Dot5 instead of Dot 3 or 4. Your brake system will last many times longer.
