Old August 24th, 2019, 04:42 PM
kcrotty59 kcrotty59 is offline
Civilian
kcrotty59 is a Soldier
Default T98 transmission input shaft
My name is Kevin. I purchased my first military vehicle, a 1968 M715. The engine had been replaced by the previous owner with an AMC 360. Using the original transmission a T98 the bell housing and everything that needed changing, was. An input shaft of 14-1/8 inches was installed in the transmission. The other input shaft (10-1/4 inches) was too short. Now my problems start. The transmission went out. I purchased another T98 trans with a 10-1/4 input shaft. Finding a 14-1/8 inch input shaft to install in the T98 transmission has been an adventure to say the least! HELP!
Old August 24th, 2019, 05:24 PM
Mikel Mikel is offline
Sergeant
Mikel is a Soldier
What's wrong with the input shaft in your old transmission?
Welcome.
Old August 26th, 2019, 12:10 PM
Civilian
The input shaft is connected to first gear, and first gear is torn up.
Old August 26th, 2019, 03:11 PM
Sergeant
Mikel is a Soldier
Perhaps you can use one from a V8 T18A, from a FSJ.
Old August 28th, 2019, 08:15 AM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
I know there are a ton of different shaft lengths for the T98...from like 6.5 to 16 inches if I remember correctly...the one we use is pretty much just for the M715 I have been told...
  #6
Old August 28th, 2019, 12:34 PM
Sergeant
Mikel is a Soldier
At that point, why not find a modern OD transmission instead?
  #7
Old August 30th, 2019, 09:46 PM
brute4c's Avatar
Grand Poobah
If it is to go behind the 230, there is no bellhousing to mount anything else to it...would have to make your own somehow...
