Old August 26th, 2019, 08:52 PM
antonio's Avatar
antonio antonio is offline
Private 1st Class
antonio is a Soldier
Default Hot alternator help me.
Hi guys, a query, my truck was running well at 24 volts, but now the alternator is very hot, very hot, smells paint burned on the body by the temperature.
Anyone know what causes such a high temperature?
Thanks for the help.
VIN : 13003 DATE : 6-67
Old August 27th, 2019, 06:54 AM
Beast's Avatar
Beast Beast is offline
Sergeant
Beast is a Soldier
Check to make sure the bearings are not going bad in it. Take the belt off and spin it by hand. If it's difficult to spin or doesn't roll smoothly, then the bearings are going bad which will cause them to get hot.
Dave
Old August 28th, 2019, 08:11 AM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
That would be my first and second guess...
If you have a working voltmeter, check the output and see if it is off weirdly...the output on the stock alternator is adjustable if it is way off somehow...
Old August 29th, 2019, 12:45 PM
antonio's Avatar
Private 1st Class
we have reviewed everything and we did not find the problem
Old August 29th, 2019, 03:46 PM
jhartings is a Soldier
Might simple be an insulation/winding/resistance issue. That would cause heat. You will need to replace the alternator.
1998 - 2019
Copyright 1998-2019
