Page 9 of 13 FirstFirst 12345678910111213 LastLast
Results 81 to 90 of 130
Thread: Axles that can be swapped in place of the stock axles
  1. #81
    never mind. I found out they`re a 44 an 60. my bad
  2. #82
    randy
    did you ever find out what the WMS to WMS was on a CUCV axle?
  3. #83
    wheel mounting surface
  4. #84
    Quote Originally Posted by hunting09999 View Post
    randy
    best Ive found is 67-68 wms on cucv. but I`m still researching.
  5. #85
    Default cucv front
    I have been looking but unable to find some pictures of a front cucv axle moded to fit. Im just curious what others have done to extend the cast spring perch.
    Any images would be a great help. Also does any one know the size of the bolt that goes into the spring perch casting?
  6. #86
    Nov 2009
    Greenwood, Indiana
    Quote Originally Posted by Specalt View Post
    Not CUCV axles, but dana 60. Give this a look. I'm not sure if it will help or not:
    Axle swap in "The Big Cheese"
    Thanks, George
    Joshua 24:15
  7. #87
    Quote Originally Posted by Flingarrows View Post
    Thank you very much, that is a huge help.
  8. #88
    For any one that is interested, I just put a 2006 dodge ram 2500 rear axle in.
    The dodge rear axle is direct bolt in. The leaf spring perches are however for a 3 inch leaf.
    In addition the dodge axle is an AAM 11.5 with 3.73 (could also be 4.10) gears, disk breaks with parking break. A single break line to a spliter for both calipers. Wms to wms is 72 inches.
    2003-2006 dodge uses the same axle.
    I picked mine up a the junck yard for $250, I will have to do a gear swap, that is going to run any where from 300-500, so for thoes on a budget it is not a bad swap.
  9. #89
    Is the bolt patten metric for the rims ?
  10. #90
    No, 8x6.5". Ford Superduty is metric, 8x170mm.
  1. porkchop : 4:10 gears in the stock axles
    By porkchop in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 12:07 AM
  2. Replacing stock axles
    By 4X4jeepfreak in forum Modified Tech
    Last Post: January 28th, 2009, 09:10 PM
  3. stock axles with 44s???
    By guswheels in forum Modified Tech
    Last Post: April 6th, 2007, 07:34 PM
