Results 1 to 3 of 3
Thread: Fuel pump Q? and hopefully some A's
    Default Fuel pump Q? and hopefully some A's
    ok... i drained the tank, blew out the fuel lines, changed the fuel filter, turned the engine over with the fuel line off the pump and it gushes good.
    even put a new rebuild kit in the one barrel holley.
    but when you mash the gas on the road it just takes a crap and dies, you can coax it a bit by pullin the choke out but i still dies... i put a clear plastic filter on it just to see whats goin on and its just a trickle comin out, not even enuff to fill the filter. do these fuel pumps die a slow death and wont build pressure?
    Did you set the float level to spec when you rebuilt the carb?
    To measure the fuel flow I put the line into a empty water bottle and crank for 5 seconds. You might have blockage at the tank. Try blowing out the line from the the fuel pump to the tank. Worked for me a couple of times.
    Yep, check the flow rate...you could have a leaking diaphragm in the pump which can be a kind of slow death thing...
  1. Fuel Pump
    By gargemel_622 in forum Stock Tech
    Last Post: September 7th, 2009, 12:10 PM
  2. need fuel civy fuel pump #s
    By jpsnblood in forum Stock Tech
    Last Post: June 24th, 2009, 09:00 PM
  3. Fuel pump ?
    By ryanroo in forum Stock Tech
    Last Post: October 7th, 2008, 09:47 PM
  4. fuel pump doesn't pump.
    By sf38a1 in forum Stock Tech
    Last Post: April 11th, 2008, 08:58 PM
  5. 230 fuel pump
    By krek in forum Stock Tech
    Last Post: May 5th, 2007, 09:29 AM
