Old February 18th, 2021, 12:48 PM
Ryan Ryan is offline
Basic Trainee
Ryan is a Soldier
Default Hard top install
I've seen hard top install "step by step instructions" referenced a few times in old threads but can't find it using search option here (keywords??!?!).
I recently purchased a hard top from Boyce Equipment but received zero directions or hardware specifications etc.
If curious it came in primer gray with sliding rear window for $1,303.00 to Denver trucking terminal.
Old February 19th, 2021, 07:22 AM
Beast's Avatar
Beast Beast is offline
Sergeant
Beast is a Soldier
First place I would look is in the Online Maintenance Manuals link at the top of the page in the header. Or you might just have to call Boyce and see if they can send you something as their top might not install exactly like the OEM hard top.
Dave
Old February 19th, 2021, 01:43 PM
Basic Trainee
Ryan is a Soldier
Thanks Beast.
The artic top found in the original manuals, although 2 pieces, gave me at least some idea of what is involved. Zero response from Boyce so far. If they respond I will share the details here.
If they don't respond I will tackle it on my own and document the process.
Old February 19th, 2021, 01:44 PM
Basic Trainee
Ryan is a Soldier
Default Maybe someone has some photos they could share?
Did your truck come with a Boyce top? Maybe you could post some shots of the installed top?
Old February 19th, 2021, 02:18 PM
Basic Trainee
Ryan is a Soldier
Default Heard back from Boyce
Copied and pasted from Boyce Equipment:
The only trick to installing one of the top is that you have to remove the C Channel along the windshield frame. You can remove it by taking a Chisel and popping off the spot welds.
Then the top will cap over the windshield frame . And the we normally just drill and pop rivet to the wind shield frame. And inside the cab we drill and pop rivet or use Screw and Nut along the back of the cab .
Once you have it on the truck. You can close the doors to see how deep to pop rivet the Aluminum trim to the top. The trim need to be cut to fit the top and back of the window opening. And you can cut a 45 degree cut in the corner where they meet to make them look nice then apply the weather strip .
  #6
Old February 19th, 2021, 04:11 PM
m38inmaine's Avatar
m38inmaine m38inmaine is offline
Private 1st Class
m38inmaine is a Soldier
I would use a spot weld cutter to remove the channel as carefully as possible, someone will need it or if the truck needs to go back original.
  #7
Old February 19th, 2021, 09:24 PM
Kaiserjeeps's Avatar
Kaiserjeeps Kaiserjeeps is offline
Sergeant
Kaiserjeeps is a Soldier
Definitely use a spot weld cutter. Using a chisel will distort the living heck out of the metal under the channel. I use them frequently and have started to use a Blair cutter. They are very high quality and come in a small blow molded case with three cutters, a shank, and an extra center pin. Sharpen your punch to needle sharp when center punching. Removing the paint will really reveal the spot welds as will a light shown from the side.
If you can please show lots of pictures. I have considered making a new metal top. It would be cool to see what you have.
  #8
Old February 20th, 2021, 10:35 AM
Basic Trainee
Ryan is a Soldier
Plan to photo document the entire process, may be a week or two before I start as the truck doesn't fit in the garage and its cold up here at 8,500 feet.
  #9
Old February 20th, 2021, 01:10 PM
m38inmaine's Avatar
Private 1st Class
Interesting one of the sellers on Ebay for the Blair cutters shows working on the inside of a M715 cab.
  #10
Old February 20th, 2021, 01:22 PM
Basic Trainee
Ryan is a Soldier
I see a lot of them for sale on Amazon, can you recommend a specific model/manufacturer?
1998 - 2021
Copyright 1998-2021
