Results 1 to 8 of 8
Thread: Replacing NP200 seals
    May 2008
    Kansas City, MO
    Default Replacing NP200 seals
    Can someone give me a quick run-through on replacing the NP200 input/output seals? I'm assuming I need to remove the brake drum to get that one, right? What's the easiest way to do that, just unhook the linkage at the lever and pull the whole assembly?
    Thanks!!
    1967 M715 w/w #11812
    Just unbolt the 4 bolts for the drum and slide it out. Wait a minute, you are stock. Just use a 1-1/2" socket to pull the nut off and slide the yoke/drum off together. Pry the old seal out and pound in a new one. Might take you 30 minutes total.
    May 2008
    Kansas City, MO
    Good deal. On the rest of them, do the yokes just slide out? I haven't looked at this real close yet. I guess I'll have to disconnect all the drive shafts.
    Should I go ahead and do the u-joints while I'm at it? They are all 1310's, right? How many do I need total?
    Jester Guest
    Quote Originally Posted by chicklin View Post
    I have found it easier to pull the bearing retainer off to get the old seal out and new one in. You have to replace some gaskets then but its way easier then trying to pry out the old one.
    May 2008
    Kansas City, MO
    Quote Originally Posted by Jester View Post
    If it's like the ones I've done on other trucks, I just take a punch and mangle the seal which breaks it loose. Then, take a pair of angled pliers, grab hold and use the rounded head of the pliers to sort of roll it out.
    Worked on an NP208, anyway.
    Yep, the "beat and pull" method works fine.
    I just changed the two inside ones since i dropped the trans for the flywheel bolts. go get a seal puller, lisle, napa, ,calvan all make them ( or package them), it looks like two flat hooks on a handle, I have used the punch and mangled them in the past. but this tool you will use forever after you get it.
    Duane
    here is the puller, available at most local auto parts stores
    http://www.sjdiscounttools.com/lis56750.html
  1. xjchief : NP200 seals
    Last Post: December 15th, 2009, 03:03 PM
  2. Replacing stock axles
    By 4X4jeepfreak in forum Modified Tech
    Last Post: January 28th, 2009, 09:10 PM
  3. Replacing heater foam??
    By Snuffy in forum Open Discussion
    Last Post: January 14th, 2009, 09:56 PM
  4. NP200 seals?
    By Mikel in forum Stock Tech
    Last Post: February 27th, 2007, 06:50 PM
  5. Need help with replacing motor
    By FireChief in forum Open Discussion
    Last Post: January 24th, 2007, 06:09 PM
