Results 1 to 10 of 11
Thread: Stock master cylinder
    northern Michigan
    Default Stock master cylinder
    I need to replace my master cylinder. Does any one have one for sale?
    Dan
    Mar 2004
    northern Arizona
    Dan, I would STRONGLY recommend you convert to a dual master system. This is easily done with a Cardone 10-1331 (i think) master cylinder, a line plug, a couple of adapters and a little line.
    If you blow your single master, or any one of the wheel cylinders, you're in no-brake trouble. Well worth the $40 in parts to convert to a dual setup for safety purposes.
    67 M725 67 M715 68 M715
    I second that. Switch over to a dual mc and silicone brake fluid after you rebuild all your wheel cylinders. Then don't worry about the brakes for another decade or so.
    northern Michigan
    I just need one to keep me going till summer.
    Dan
    I have an NOS one sitting around...its never had fluid in it but is 30-40 years old...pm if you are interested.
    I was looking to do this last fall when the brakes went. I got a number of TS 101371 from Napa. Is this the same?
    US ARMY
    Napa carries the stock master...its really pricey though...look up this number with them:
    UP 35036
    Jan 2009
    SE Portland,Oregon
    Almost always NOS ones on Ebay for under $50.
    northern Michigan
    Brute4c
    did you get my email yesterday.
    Dan
    I did get the pm you sent...I replied at 11pm last night...did you not get that?
  1. New stock master cylinder needed...
    By Fastfrankie in forum Stock Tech
    Last Post: August 13th, 2009, 09:30 PM
  2. Stock master cylinder
    By gimpyrobb in forum Stock Tech
    Last Post: June 5th, 2008, 09:33 AM
  3. Stock Master cylinder rebuild kit
    By DAVEJ in forum Stock Tech
    Last Post: June 20th, 2007, 12:21 PM
  4. master cylinder Q.
    By kaiserkoski in forum Stock Tech Archives
    Last Post: April 27th, 2004, 09:40 PM
