Results 1 to 9 of 9
Thread: spark plugs- Brute4c
    San Antonio,Texas
    Jon
    i could not get the parts file to work and i am looking for the civvy spark plug part number.
    thanks
    k
    67 M725 84 GW
  2. Default spark plugs- Brute4c
    Autolite #275 is what the Zone parts list says.
    1969 M715
    San Antonio,Texas
    Default Cannot login!!!!
    thanks D
    my dialup is killing me.
    k
    67 M725 84 GW
    Sorry I didnt see this earlier...but yeah, the 275 Autolite or equivalent is correct.
    would there be any advantage to going to the bosch platnumx4 plugs if i could get the autolite equvialent
    -brad
    '86 & '98 Ram 4x4's
    I dont think there are alot of choices in high perf spark plugs that cross to the Autolite 275...just basically the regular types I think...If such a thing is out there....cannot see any reason it would hurt...other than your wallet maybe...
    Default 2 bbl intake
    are there 12v military spark plugs out there or do the 24v ones work fine?
    Spark plugs work on what the coil sends....older point ignitions generally start around 30,000 volts and modern HEI's can exceed 60,000.
    12 or 24 volt is irrelevant to the plug....
    Thank you
  1. shepsjeep : Spark Plugs...
    Last Post: November 12th, 2009, 05:43 AM
  2. Spark Plugs
    By pghjeeper in forum Stock Tech
    Last Post: February 15th, 2009, 09:26 AM
  3. spark plugs
    By partmaster in forum Open Discussion
    Last Post: January 16th, 2008, 03:16 PM
  4. Spark plugs...
    By Mot-Man-616 in forum Stock Tech
    Last Post: July 19th, 2007, 11:54 AM
  5. Spark Plugs
    By Armada in forum Open Discussion
    Last Post: April 6th, 2007, 02:15 PM
