I finally dipped into my wallet for a new gas filler neck before the old one turns to crumbles. I've only been putting it off 9 years now....
Before I go to do the swap--are there any things that tend to bite or tips/tricks to save hassles? Everything looks obvious...but tight clearances and fit might make the change a bit fiddly. I figured it was better to ask a silly sounding question before I dug in and had issues than battle something there was an easy procedure to accomplish if you knew the "trick".
Hopefully the answer is "Goes right in, slick as snot".
